-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Safety Cable to Chains (https://www.offshoreonly.com/forums/trucks-trailers-transportation/382125-safety-cable-chains.html)
Brad Christy 04-11-2024 08:51 AM
Guys,
I haven’t liked the safety cables that are on our trailer from the time we bought the boat. They’re stiff, unruly, and are starting to fray a bit at the loops (they were like that when we bought it), and they have a tendency to bite while handling them. I would really like to replace them with chains.
https://cimg1.ibsrv.net/gimg/www.off...321416d0d.jpeg
The hooks are labeled as 5/16”. My guess is the cables are actually 3/8”, with the covering and a little bit of bend expansion accounting for it measuring 1/2” at the bent loop. Is it safe to go with 3/8” link chain? Or should I go bigger? Are the quick links OK to o connect the hooks to the chain?
Boat and trailer weight a combined ~7000lbs dry.
Thanks. Brad.
Brad Christy 04-11-2024 09:26 AM
Originally Posted by Brad Christy (Post 4895310)
Guys,
Thanks. Brad.
Nevermind. I just bought a couple of pre-fabbed safety chains with forged hooks, 10K lb load capacity each. I think we're good. :cool:
Thanks. Brad.
BBYSTWY 04-11-2024 06:06 PM
Did the same thing on my Nordic...got mine from etrailer and they were sold as a kit by weight...sounds like you're all set lol
Wally 04-12-2024 07:44 AM
You have to look at the chains working load limits. A "Typical" 3/8" chain has a working load limit of around 8800lbs so it should be plenty good for your application...just make sure you can verify the load limits as ive seen some very cheap chains sold at stores that i wouldn't trust hold a back yard gate closed!
Also make sure you have enough length of chain to criss-cross under the trailer tongue and still be able to make tight turns....but im sure you already know that :D
Brad Christy 04-12-2024 07:54 AM
Wally,
Yup. This is what I ordered:
Safety Chains
I think we’re good.
Thanks. Brad.
Padraig 04-13-2024 11:37 AM
When I replaced my coupler and added EOH brakes, I put on cable type. Will be going back to chains too.
Padraig
