Any Dodge Cummins heads around ? >
Old 03-11-2005 | 06:54 PM
  #31
eMotiondriver's Avatar
Default Re: Any Dodge Cummins heads around ?
[QUOTE=
under heavy accel at top of rpm drops to almost 5-6 (good or not ?) and as far as the condition i explained to them...tech couldnt verify customers complaint.[/QUOTE]
NOT GOOD
eMotiondriver is offline
Old 03-11-2005 | 06:55 PM
  #32
Speed sensor
Old 03-12-2005 | 06:09 PM
  #33
berns29scarab's Avatar
anybody know what the minimum fuel pressure should be ?
berns29scarab is offline
Old 03-12-2005 | 11:42 PM
  #34
Cat Skinner
5 to 7 PSI at wot is fine. Should have 14-15 at idle. If your max egt is 650 then I'm guessing your probe isn't in the exaust manifold. Watch out, that is a false reading. You should add about 350 for pre turbo readings. I suggest you drill and tap your manifold and put your sensor there. Buy a fuel pressure gauge and check it every oil change or put one in the cab. Lift pumps are $160 from Cummins and can be changed in about 20 min with a little practice. I always carry a spare.
Have fun,
Cat Skinner
Old 03-13-2005 | 09:55 AM
  #35
i have pyro, boost, and fuel pressure guages in the cab. cold air intake and a 4 inch exhaust from the turbo back...max boost at wot is 28, the hottest it gets is 650, and at wot fuel psi drops to 5-6...at idle its about 12-13..i'll have to look and see where they installed the probe
Old 03-13-2005 | 09:58 AM
  #36
SHARKEY-IMAGES's Avatar
OSO Content Provider
Commercial Members
Question Re: Any Dodge Cummins heads around ?
How much did your performance change Bern when you changed out the exhaust to the 4"?
www.TimSharkey.com/
Digital Photography & Video one BYTE at a time !
SHARKEY-IMAGES is offline
Old 03-13-2005 | 11:36 AM
  #37
it is noticeable better throttle response, turbo spools up quicker and sounds awesome...
Old 03-13-2005 | 11:42 AM
  #38
I have 4" exhuast also I got better MPG and the turbo spooled up much faster. It added about 30hp according to dyno sheet.
My pyro runs about 530- 640 under normal running when I turn the fuel up to 63% over stock if will reach 1150+ for a second then the box defuels till it's under 1100.
Old 03-13-2005 | 11:46 AM
  #39
http://mysite.verizon.net/bunkyman/RamSmoke1.mpg
2001 Ram Video with 4" Magna flow exhuast and blue chip box.
Old 03-13-2005 | 11:52 AM
  #40
Cat Skinner
Really? Did the dyno operator sell the exaust to you?
CS
