Stupid tongue weight question??? >
Old 04-04-2005 | 07:58 PM
t500hps's Avatar
21 and 42 footers
Default Stupid tongue weight question???
There have been a thousand threads about trailer tongue weight, but I have never seen this question.
Is there some magic formula to calculate how far forward (or back) a boat would need to be moved to change the weight on the tongue?
I have a 31 Formula that weighs 8,000# empty, 130 gal. fuel, 1500# aluminum 3x trailer. I need approx 1,000 lbs of tongue weight, but just measured and only have about 275!!!!
I'm guessng I need to come forward about 10 inches, but any suggestions?
t500hps is online now
Old 04-04-2005 | 11:29 PM
buck183's Avatar
Default Re: Stupid tongue weight question???
Too many variables IMO. All trailers are different, and all boats are built different. What would work on one wouldn't work on another.
It's going to be trial and error. I say try a couple inches at a time. You would be surprised how much difference a couple inches can make on your tongue weight. (not to mention a a few other things)
You are on the right track for the amount of weight you are looking for though.
Buck
buck183 is offline
Old 04-05-2005 | 03:41 PM
Reckless32's Avatar
Rough Seas Lie Ahead
First of all, you want a trailer that is level when loaded and hooked up to the hitch along with a 5-10 % tongue weight ratio. For instance you're saying with approx. 812 lbs of gas; 8000 lb boat; 1500 lb trailer you've got a total of approx. 10,312 lbs. Using roughly 10% tongue weight (0.07 x 10312) you should end up in the ballpark of 721 lbs. Then be sure you have a level trailer so that all the weight is evenly distributed over all three axles so that one axle isn't taking all the punishment and either fails, or blows a tire. Be sure you have the right slider with the proper drop distance to keep it all level.
Reckless32 is offline
Old 04-05-2005 | 04:27 PM
Sean H's Avatar
A to Z
you say 10% but then use 7% for your calc???????
Sean H is offline
Old 04-05-2005 | 05:41 PM
t500hps's Avatar
21 and 42 footers
It's that Virginia math....hey how come I know what he's talking about???
Old 04-05-2005 | 05:57 PM
Sean H's Avatar
A to Z
i thought that was west virginia math...
Sean H is offline
Downtown42
28
05-12-2005 07:26 PM
jackhammer
4
06-09-2004 12:42 AM
JON242
10-13-2002 11:32 AM
Ike
03-27-2002 10:00 AM
