-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Propeller for 280 (https://www.offshoreonly.com/forums/velocity/105304-propeller-280-a.html)
velocitypwrbtr 06-10-2005 03:14 PM
Propeller for 280
What is the best prop for a 280 with a 540 600hp? What is everyone seeing for prop slipage?
Padraig 06-10-2005 08:03 PM
Re: Propeller for 280
I would call Mike at Hall propeller. He is a genuis at working Velocity Props. I am running a labbed 26 Hydro but with a mostly stock 502 mag. what are you running now?
velocitypwrbtr 06-10-2005 08:22 PM
28p Hydro @ 5400 rpm would like to try a bravo one 4-blade I have too much slippage and cavitation
bglz42 06-11-2005 06:15 AM
On my 26 Thoroughbred, I'm running a Halls labbed Bravo 30". My slip numbers are still a little high, but the midrange is better than my old Hydro. Also, I like the handling much better with the Bravo. I think I gave up a little speed, but it was worth it. I tried a new (unlabbed) 26" Hydromotve Q5X five-blade, (borrowed), and it was NICE! Picked up some serious mid (3500 rpms/50mph) and felt really good. That's my next prop for sure. Slip as down to around 10-12%, too.
Jim
FFO 06-27-2005 08:46 PM
bglz42 What H.P are you running . Also what top speed did you see with 5 blade .
velocity280 07-08-2005 05:39 PM
I have a '96 280 with 540 and a little over 600 hp and run a labbed 30 bravo by Mike Hall. He says I really should use a 32, but don't have the extra money. I have turned the prop as high as 5600 rpm at about 83 on gps. Hit a little sand bar here at Havasu and took some of the edge off and down to around 5400. My mid range is awsome...I can accelerate as fast as a lot of blown boats.
offshorebankin 08-31-2005 06:46 AM
30 lab all the way...
docbones 12-22-2005 10:14 PM
I had a 280 with HP500 and B&M Blower approx 650Hp.
With 30P Bravo 1 rode too flat and 85 MPH
With 29 labbed hydro totally different attitude and 88 MPH.
I recommend the hydro labbed hands down. I did not like the Bravo at all!
mikes280 12-24-2005 08:42 AM
i run a 32labbed bravo turn it right at 6000 but i thank it runs to flat may let mike do some work on it for next summer i also wont to try a 5 blade
risky 01-02-2006 01:34 PM
what kind of speed should a 280 (1996) with a merc 500 carb see?
spit 01-04-2006 04:17 AM
76gps
risky 01-04-2006 08:09 AM
Thanks spit, looking to buy one at local shop but don't know much about. so if I work engine a bit and have right prop I could get high 80's ?
risky 01-04-2006 08:12 AM
Thanks spit, looking to buy one at local shop but don't know much about. so if I work engine a bit and have right prop I could get high 80's, I saw this in previous posts, Does this hull handle that speed well?
spit 01-04-2006 12:56 PM
600 H.P. should get you 86+
ls1nova 01-08-2006 07:46 PM
Anyone have the phone # for Hall's propeller? I searched on the net but can't find it.
Frank
spit 01-10-2006 07:24 AM
407-402-8148
docbones 07-17-2012 07:51 PM
HP/speed
These hulls do best imho over 80 MPH and they love to be aired out!
