Originally Posted by VelocityRick
(Post 2528151)
Wow. Looks great Pat. Give me a call. They were labeled, but I have pics to help you. I don't know who does the rigging for Velocity, but they had wires everywhere. It's wired exactly the same as a standard 502. Pull the wiring schematic from Mercruiser and match the wire color to each sender.
I have the Merc books for my engine (1997 502Mag MPI). I'm sure the harness will plug in and most everything will work. It will just be the stuff that is not standard on most boats like oil temp and such. One question for you: Where both batteries mounted on the port side when you ran a right hand prop? |
Originally Posted by Pat McPherson
(Post 2528530)
Thanks Rick...
(Post 2529561)
I bought the boat with both batteries in the port side. The prop has alway been left handed. You will have to switch the cables to the throttle to run a right handed prop. Ducky's still has my old prop. I'd get it.
Now you've got me rethinking my purchase of a RH prop. I'll call Tom and ask what they want for the old prop. |
Ricky,
He's gonna be runnin different power than you. The prop might be a little tall. I think your gonna miss the V. That pantera bottom isn't gonna hang this year:D:D |
Originally Posted by Vicious22
(Post 2532305)
Ricky,
(Post 2529561)
I'm going to try my buds LH 26p B1 and my RH 26p B1 back to back and se how she runs before buying another prop. |
| All times are GMT -5. The time now is 10:39 AM. |
