speedmasters on 30 Velocity? >
Old 04-08-2008 | 01:43 PM
I had #2;s on a 33 turbo fountain back in the 80's.Had a lot of trouble with the drives and wasn't making that much power .If you can swing it Konrads are the way to go.The mechanic I use has rigged a bunch of them and no problems yet.The 30 I had was set up at lake x for Velocity with # 3's.They held up pretty good unless I got carried away.Still miss that boat !!!
notda1 is offline
Old 04-26-2008 | 07:16 AM
Andy when Boyd the owner bought the parts block,rods and crankshaft they were set up to be 608" motors, way to much for the 671 blowers he already had. And way to big for the boat so we had Roger at Aires Pistons build a piston that would work in both blocks with a 4" crank. The block deck heights and rods are different from each other also. I think the first cranks were 4 5/8.
RWMARINE is offline
Old 05-25-2013 | 11:46 AM
Dump it for 20?
anthonystempak is offline
Old 05-25-2013 | 03:17 PM
Still not right is it those props look a little big
Doesn't it need the long flaps
Old 05-25-2013 | 07:20 PM
Holy crap old thread, check out newer ones. Got rid of the speedy twos installed jet drives and do 137 all day long...Na on the 20K but thanx anyway. Good boat, not the fastest or coolest but will hold her own against my buddys $200K boats, pisses them off.
Andy is offline
Old 05-25-2013 | 09:43 PM
wow jets , very impressive numbers over your old drives with the same power .
notda1 is offline
Old 05-25-2013 | 10:19 PM
that hull wasn't (said) to run with choppers l guess it will
Probably why it needs so much hp
Old 05-25-2013 | 10:39 PM
I might
Old 05-26-2013 | 10:00 AM
Haven't played with my boat in over a year had a fire on another boat that was ten feet from mine scorched the paint and put three 4" blisters on the glass. Still running TRS, still haven't popped a drive, yet.
Andy is offline
Old 05-26-2013 | 02:32 PM
Looked better purple l don't like that orange, was it roosting with those chopper props?
