Bought engines today VV >
Old 08-21-2009 | 10:37 PM
  #781
Originally Posted by Velocity Vector
I'm planning to leave the drive water like it is at the strainer and run the pickups to the strainer in the other 1 1/4" hole I have there. Am I thinking wrong? Both going in the strainer and the pump sucks from the bottom of the strainer.
ABSOLUTLEY ,,,,,thats what i would do,,,more water ,,,better pressure !!!!!!
DareDevil is offline
Old 08-22-2009 | 10:42 AM
  #782
Kinda like maken love?
Maybe for some, but others require pumping!!
DKerns is offline
Old 08-22-2009 | 10:59 AM
  #783
On this boat and my last they they are mounted at the transom . I think you want to leave the running surface as undisturbed as possible . Teague makes an adjustable one to adjust the height to modify the drag and pressure .
notda1 is offline
Old 08-22-2009 | 12:26 PM
  #784
Velocity Vector's Avatar
Crazy Energy
True but to get to the transom I would have to pull headers to get to it. Did you get home safe?
Velocity Vector is offline
Old 08-22-2009 | 12:35 PM
  #785
Crazy Energy
Hi D, I got your call but i think I didn't call back. I'm sorry. I'll hollar at ya.
Old 08-22-2009 | 02:47 PM
  #786
My location
Andy is offline
Old 08-23-2009 | 04:59 PM
  #787
mine are on the bottom of the pad on either side of the speedo pick-up , the speedo never seems to work on this boat anyway
notda1 is offline
Old 08-23-2009 | 05:28 PM
  #788
KC,
I am installing a beam and trolly in my building. We can lift one engine out and do the work. Wait for offseason and we will set them on the transom?????
TxHawk is offline
Old 08-23-2009 | 07:43 PM
  #789
Crazy Energy
Originally Posted by TxHawk
KC,
That sounds great but what do I do with these two big holes I drilled in the bottom of the boat?
I think I can drill a hole right through the top of extension boxes slap in a 12-An bulkhead fitting and route the drive water right there over the drives. I took the side plate off the boxes and have good access to the water hose. Reduce the 1-1/4 to 3/4 out the top and over the drives. Use the two thruhulls for the motors.
Old 08-24-2009 | 12:10 PM
  #790
Crazy Energy
OK, here is what I came up with to discharge the drive water....This is a replacement of the OEM plastic inlet supply on the Bravo drive that allows stainless braided line plumbing. The adapter has 3/4" NPT threads and is hard coat anodized. I'll replace the old plastic 1 1/4" with this 3/4 inch and route it out the top of the extension boxes with a 90 looking towards the back to help cool the drives. I'll let you know how it works out. This should be a good clean exit. Thanks again
