Velocity questions >
Velocity questions
Velocity questions
Old 05-22-2008 | 10:05 AM
So every one out there doesn't run superchillers? I guess i'll try and make it work will keep you guys informed of how it goes.
stoltz is offline
Old 05-22-2008 | 04:45 PM
Originally Posted by stoltz
How do I get in touch with Velocity Mike, 28 thoroughbred or Velocity Mark . Do you guys have super chillers on your boats? If you do how did you get it under your hatch? or did you have to cut things? I have talked with Steve Stepp he has been very helpful, but I wanted to get other people opinions. I want to get as much info as I possible can. This is the only velocity in Idaho and I want to make it work the very best it can. I hope that you can help me thanks for your help everybody.
I do not run a intercooler but Mikes 280 runs a Whipple intercooler its low profile. Its made into the intake and I beleive its only a 1" higher. I make upper 9s in HP. Call me if I can help 704-361-7893 Gary
28thoroughbred is offline
Old 05-22-2008 | 09:03 PM
VelocityMark's Avatar
Just saw your post we are easy to find. Good luck with your project it sounds like it will be nice. I also run a 1071 without an innercooler on a smaller motor than Garys. As for the NACA ducts I don't think that 2 are enough to feed 800+ HP, I bought a second set from Steve last year and just have not had a chance to install them yet. Also I have not given up on the Shortie yet just have not played with much because I only have one prop that I can run with it.
VelocityMark is offline
Old 05-22-2008 | 10:38 PM
Default mark
I have 4 naca ducts in my boat two that feed directly into in carb and two that feed into the engine compartment. I also have two more that feed out of the hull.
stoltz is offline
Old 05-23-2008 | 09:24 AM
I am going to pull my hatch apart this weekend and see what I can come up with. I feel that I can make this work without a big hood scope, maybe I can just cut out the foam and put a little raise in the vinyl. I can keep you guys informed on my project and i'll try and figure out how to put some pics. on here. One other question for you guys. The steering on my boat is a full hydraulic system, but it only has one ram. Do you fell this is enough with my setup?
stoltz is offline
Old 05-23-2008 | 12:29 PM
2 naca ducts are sufficent, as for the drive i would definatly start with the standard lenght but i would plan on investing in a imco sc or at least a xr befor long. I put single rams on boats below 90mph and anything faster i always reccomend duel rams, i find it makes the boat a little better in the handling department when trimming
velocitykid is offline
Old 05-23-2008 | 12:48 PM
Sick Stinger's Avatar
Brotherhood #1
STolts, I already did what you did over the winter and just finished last week call me if you want. I have a 572 with a 10-71 superchiller intercooler on a 93 26 Velocity/Tbred Kevlar.
-Mike
Sick Stinger is offline
Old 05-23-2008 | 05:34 PM
mikes280's Avatar
we took garys boat with 2 naca ducts and i feltit was not geting enough air so he rigged away to run the boat with the hatch up 2 inches and the boat took off so NO 2 are not enough
mikes280 is offline
Old 05-23-2008 | 07:04 PM
Brotherhood #1
I have all 4 facing to the read and a scoop. 1 to clear the sunpad and another to get enough air to feed it.
-Mike
Old 05-23-2008 | 08:31 PM
Velocity Vector's Avatar
Crazy Energy
Here are my nasty naca's
Attached Thumbnails Velocity questions-ff0b_1.jpg   Velocity questions-0028_1.jpg   Velocity questions-601517_6.jpg
Velocity Vector is offline
