260 bilge thingy >
260 bilge thingy
260 bilge thingy
Old 08-06-2010 | 09:09 AM
thanks.
as luck would have it, I will probably be pulling the motor this winter anyway to fix an oil leak, so access might not be a problem.
What is involved with removing the balsa core? I am envisioning grinding away at the hull, and that scares the crap outta me.
cabin fever is offline
Old 08-09-2010 | 08:53 AM
Revelocity's Avatar
Originally Posted by cabin fever
thanks.
Cut out top layer of glass using a hole saw witout an arbor bit (or a very short one). Use a razor blade/scraper and sand paper to remove balsa.
Revelocity is offline
