StillCrazy Velocity...Resurrected >
Old 08-06-2011 | 04:43 PM
  #401
2011-08-06_12-29-53_399.jpg by JordanPoppa, on Flickr
2011-08-06_12-29-20_664.jpg by JordanPoppa, on Flickr
StillCrazy J&M is offline
Old 08-06-2011 | 05:04 PM
  #402
wow, thanks for the ride.
bounce is offline
Old 08-06-2011 | 07:15 PM
  #403
Thank you for the pictures, very nice set-up. Who built the back bolster for you? I think I am going to go that route on mine.
Craig
captaincraiger is offline
Old 08-06-2011 | 08:17 PM
  #404
Wow... amazing story
Great work, this is the stuff gear heads just live for. Thanks!
tgtint is offline
Old 08-08-2011 | 07:00 AM
  #405
Craig
Velocity built the bolsters. The frames are made of some high strength lightweight composite material. I had them build half bolsters in the rear to give people at least some lateral support vs a flat rear. Its worked out great so far.
Old 08-08-2011 | 07:45 AM
  #406
dykstra's Avatar
I love this thread so much I re-read it 3 times! Just an awesome story. Congrats and enjoy. Wicked cool!!
Dave
dykstra is offline
Old 08-30-2011 | 09:41 PM
  #407
Awesome Boat Guys !!!!
Was that you coming through Government Cut last Sat around Lunch time ?
limitless is offline
Old 09-09-2011 | 03:19 AM
  #408
Sorry I missed the last post. Yep, that was us coming through Gov't cut! We had a fun ride down from TNT and Haulover. Took Eddie and Cesar Guardado out for the day...which was really cool as it was the first time they'd seen the boat after it left their shop from paint and now it's a living breathing thrill ride
Sucked some seaweed into the starboard engine however when I fired her back up after lunch at Bayside. We don't have sea strainers so that was a pain in the a** to say the least. I took apart the water pump and hoses and got enough out to keep temps down and run back most of the way, but in the last no wake zone going to TNT the temp started rising again so I just shut it down. Needless to say some sea strainers are on my must do list!
Regardless, it was a blast running around Miami and we definitely plan on coming back soon as the day was cut short by seaweed and the water is just awesome over there.
-Jordan
Old 09-09-2011 | 03:24 AM
  #409
After the seaweed episode, can anyone tell me what the best way to flush the system and get out any small seaweed particles is? Is there a way to flush with water in reverse so that any seaweed will be forced back out the way it came?
Old 09-09-2011 | 06:26 AM
  #410
Audiofn's Avatar
Charter Member #232
You can try and remove the hose at the T-stat housing and water pump out, then at the water pump in and back flush that way. You need a hose with good preasure. Some times it can help to kink the hose and then let it go again for that initial high preasure surge. If that does not work you have to kind of start pulling crap apart. Check your impeller and housing as it may be smoked as well, only takes a few seconds to ruin them if there is no water.
Put your best foot forward!
Audiofn is offline
