-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   41' prop? (https://www.offshoreonly.com/forums/velocity/252366-41-prop.html)
ckin62 04-27-2011 04:58 PM
41' prop?
Finally close to getting my 41' in the water again and starting to think about what prop to start with. Have procharged 540's with rite at 750hp and -2 sportmaster xr's. What are your thoughts on props?
Before ran 80mph with stock 500's and 4 blade 30 pitchers.
ckin62 06-02-2011 10:21 PM
Well, ended up not getting on plane with above setup and Hydro 33" 5 blades 15" dia. I put the standard lowers on and went 94mph close to 5000 rpm. Drives were all the way in. I am adding 2" spacers to get the Sportmasters to dig in. I want to trim some and be at 5200 rpm. Was thinking of trying a 34" P-5x, or a 33" p-5. Which would be a better fit? remember lowering the drives 2". Thanks
Velocity Tom 06-03-2011 08:17 AM
If its a stock x dim. use a 1 in shorty it work best. but you have to run a 5 blade. to get the boat up on plane.
we allways ran hydros done buy Mike at Halls. I like the drives towed in 1/8 in.
offshorexcursion 08-05-2012 04:12 PM
What did you end up doing with props? Hows the boat running?
ckin62 08-15-2012 08:13 PM
Boat runs great. I went with the 2" spacers and Maximus 32s for mid range performance. I also have a set of 33s hydros. Trimmed out running just north of triple digits. However the almost nonexistent diffuser ring makes getting on plane a chore.
