Nose Cone Time? >
Nose Cone Time?
Nose Cone Time?
Old 12-02-2011 | 07:52 PM
mikes280's Avatar
Originally Posted by Kings11
What I'm trying to get at with the later cone question is, no one is worried the cone will deflect the water away from the side pick ups in the lower case at speed causing you to lose water pressure amongst other issues? As I see everyone uses a hydromotive cone, yet the only cone I've seen online from hydromotive has no water pick up.
i run the imco and you can get it with a low water pickup, i think the imco is faster then the hydro and i felt it improved handling at speed
mikes280 is offline
Old 12-02-2011 | 10:02 PM
Can get them kind of goes around the question though. Less holes you drill into something less likely something can leak. I'm already not a fan of having to drill my upper so the Imco Cap will fit for external steering. A latham cap just looks more appealing to me for the lack of drilling required.
Thanks for the answer though!
*edit* Talking about having to drill into the Upper to tie in the water pick off of a cone.
Kings11 is offline
Old 12-02-2011 | 10:30 PM
mikes280's Avatar
not sure what you mean , i run a imco nosecone on a stock xr merc lower ,not a imco lower. also i do not run the low wayer pic up on mine and i make 10 lbs of water presure.
mikes280 is offline
Old 12-02-2011 | 10:40 PM
That's what I'm looking for. You mentioned a low water pick up so I assumed you were using that one.
I'm just trying to find out if I can run a Cone with out a low water pick up. Asked the question a couple of times to a couple of different people off and on the forums and they re-iterate my question with both are available, but don't answer it.
Thank you.
Kings11 is offline
