Transom Soot
I also wonder if longer exhaust tips would help this. There was a post not to long ago with one of the members changing out stock exhaust tips (5 in) i believe for longer ( 10 in ) if not mistaken. Im wondering if the exhaust being further from the boat would help.
For what its worth a very good friend has a 29 fountain (525 blue motor) that is worse than my boat is for soot. I believe the boat is mid 2000 or so.
I was told the same thing about factory tunes , there have been several tunes after mine.Keep us updated as to turn around time and how the boat runs after. I believe that Whipple is one of if not the only "Authorized" shop to re-flash/program Mercs ECU'S
I finally got a reply back from Dennis @ Whipple on their PCM reflash, Stage 2 = $745, that's allot of coin for soot control and a only 5 to 8% gain in power. I'm gonna look at it this way, Merc's reflash is free, so why not. If I'm still not satisfied the Wipple reflash may have to be done...............time will tell.
Whipple Stage 2: $745 + $40.00 shipping; $785.00 out of pocket
Pretty much a no brain'er for the time being. I'll give your Whipple post a look-see this evening.
Thank you
My engines are also 2003. After I had the reflash done it cleared up at least 80% of the soot. Also only use 87 octane.
Here's the story, 2003 motor, ran the serial number on the PCM, there have been "7" upgrades on this model PCM and my serial number had not one of them. Spoke to my Merc Master Tech in S.C. who researched the PCM S/N and he'll get Merc to reflash it to the latest revision. Soooo that being said, it's on it's way to S.C. to be shipped to Merc (thru an authorized dealership). About 2 weeks is what I'm told to turn it around.......I'll report back when its back on the motor and the first time out with the reflash.
Update:
PCM is back after a Mercury Reflash to the current revision for this motor/PCM combination. About a 2 week turnaround for the reflash.
Haven't been on the water since the reinstall, weather has been horrible here. I plugged in my laptop (running the RINDA DIACOM) to the PCM Diagnostic port and found no codes other than the normal "GHOST CODES" for sensors that are not on the motor, this way I know I'm starting out with a clean slate. As soon as I'm able to get out, I'll report back on results of the reflash addressing the "SOOT" problem, as an added benefit I was also told there has been an improvement in the PCM controlled timing on the motor.
Thanks all for sharing your information......
