-   Wanted (https://www.offshoreonly.com/forums/wanted-244/)
-   -   Bravo gimble ring or transom assembly (https://www.offshoreonly.com/forums/wanted/353389-bravo-gimble-ring-transom-assembly.html)
DBleil89 04-15-2018 03:14 PM
My humble ring is worn and needs replaced. I would see if anyone has a good gimble ring or a transom assembly for sale
AllDodge 04-15-2018 05:35 PM
Have a transom assembly removed from my 1994 cruiser during rebuild which happened in 2015. Its a fresh water assembly, and some years back before rebuild I had the ring rebuilt and installed a new pin. When replacing the pin I used the Merc method and drilled and tapped holes on the side. Taking a WAG think I replaced the ring in 2010. Pic below is before it was removed and right after. Can take other pics, and have removed the cylinders and lower manifolds. Will take $300 plus ship and I'm in KY
https://cimg0.ibsrv.net/gimg/www.off...56dcea4a48.jpg
https://cimg7.ibsrv.net/gimg/www.off...1aecd8a15f.jpg
AllDodge 04-15-2018 06:01 PM
Here are more pics, and this is just for the parts seen. Just did check gimbal bearing and its real smooth no ruffness
https://cimg5.ibsrv.net/gimg/www.off...71c30a0b5d.jpg
https://cimg6.ibsrv.net/gimg/www.off...ead28b5847.jpg
https://cimg7.ibsrv.net/gimg/www.off...b743e68e8c.jpg
https://cimg8.ibsrv.net/gimg/www.off...58c0fc9866.jpg
AllDodge 04-15-2018 06:04 PM
https://cimg3.ibsrv.net/gimg/www.off...a963a57105.jpg
Well it only did two of the pics, here is two more
https://cimg6.ibsrv.net/gimg/www.off...457d25250c.jpg
https://cimg7.ibsrv.net/gimg/www.off...45ab9f9885.jpg
DBleil89 04-15-2018 06:06 PM
Maybe try email at [email protected]. also if you have time give me a call so we can iron out the details
