Mechanical fuel pumps needed
Need 2 454 bbc mechanical fuel pumps. Running Holley 750 carbs. Intake and cam motor. I don’t think stock ones are doing it anymore. What does everyone have out there? |
my buddy was running a 540 with a 1050 dominator with the stock pump and the after market base plate. i thing it was the hardin Marine one.
You get this pump, take the bottom off, and bolt it to the top of the stocker if you’re running it off a sea pump. If it’s a block mounted pump then you’re good to go. You will need a regulator. https://www.summitracing.com/parts/hly-12-454-13 |
https://www.hardin-marine.com/p-12460-high-performance-fuel-pump-upgrade-bbc-gen-5-6-engines.aspx
Originally Posted by freekazoid
(Post 4655105)
Airtex makes the Merc pump 60932
Originally Posted by Baja Rooster
(Post 4655107)
If that’s the KE unit, some people have good luck running it but many of us find it to be junk and going back to stock or Holleys. |
Did you find your fuel pumps? If not I have a few new and good ones I don't need anymore.
Dennis 248-640-4114 |
I ended getting some. Thank you tho |
| All times are GMT -5. The time now is 12:52 AM. |
