496 power steering pump
Needing one to finish an engine. Merc is 2 weeks from getting one.
Have not finished my research but see this may be useful
https://cimg5.ibsrv.net/gimg/www.off...692c0fe5cb.jpg |
Mine has a 3/4 shaft. I'd get one of those if I could locate a pulley that would fit.
Looks like the newer model 496 which was part number 865710T which is NLA
The older model remains available (806230T) and uses pulley 862751 https://www.mercruiserparts.com/bam/...1816/11414/230 |
I wonder if there's difference in pulley size. The one I have is 4.5 od. I think it would be worth it to buy a pump and pulley to try it
Don't know for sure but if you select the part link the dimensions list
4.65 x 1.75 x 5.88 Most likely the worste that would happen is need a different length belt https://www.mercruiserparts.com/862751-pulley |
Just buy the pully separate. Im sure they are in stock at mercruiser parts.
The pumps pictured above are GM Type II (Saginaw TC series)
OP , .750 = 19mm So, fir a search on the net type in GM Type II 19 mm shaft These pumps have replaceable psi/volume regulators, so make sure to install what was on your pump. |
Ok sweet thanks
I purchased this one recently was quick shipping and flawless.
https://www.ebay.com/itm/282628541247 |
| All times are GMT -5. The time now is 09:31 PM. |
