NXT drive oil Amsoil?
The Lucas additive is ABSOLUTELY NOT needed! If AMSOIL wanted their gearlube to perform with excessive drag on the gears they would make it that way to start. The Lucas will cause a condition called fluid friction which in turn will increase the drive temps. The AMSOIL Severe Gear is ALL you need, period.
Amsoil Extreme Gear is what Bob Teague is running in his 6's, check out his latest press release. Don't dilute your Amsoil with other additives or oils, if you study the test data you won't do it.
http://teaguecustommarine.com/teague...r-in-st-clair/
