Allowable vertical play in B1 >
Old 03-13-2013, 05:57 PM
BDiggity's Avatar
Originally Posted by picklenjim
Just for your info, They use loctite in those hinge pins from the factory and your supposed to use it anytime you have had it apart. Thing is lot of times it will wipe out the threads just taking it apart. Helicoil sound good.
learned that the hard way. had to buy 4 new pins. heat definately helped loosen them up. had to helicoil both on one of my drives when installing new pins.
BDiggity is offline
Old 03-13-2013, 06:53 PM
Picked up a heli-coil kit today. I just hope that the opened up hole still has enough material for the STI tap to work. If not, I have a plan to make a solid bushing on the lathe.
Thread an OD of whatever pitch I have tap to match, then thread the ID 5/8-18. If I go this route I'll do both sides.
One question- what are you guys using for heat? I'd rather not cook the finish off my gimbal ring to remove the other hinge pin.
Apparently the red Loctite starts to break down at 360*F, per Loctite. That being the case, I think I'll try the heat gun.
Cole2534 is offline
Old 03-13-2013, 08:22 PM
I think the stock threads are 5/8. I had my bellhousing welded and then re tapped using the original pin.
jbraun2828 is offline
Old 03-13-2013, 09:27 PM
They are, 5/8NF.
Cole2534 is offline
Old 03-17-2013, 08:53 PM
Default Here's my remedy
Well I got it all apart and did a halfass job of documenting what I did-
This hole is a little bigger than stock-
Luckily, the other hole was good. So we set the bellhousing on blocks on the surface plate to get a measurement.
Going back to a round hole, it finally cleared up around .968", guess that explains my slop.
I got in the rhythm and forgot to take a pic of the lathe work, but as you can see the hole is smaller.
From there I installed a Heli-coil and went back together with it.
Aside- the socket I cut for gripping the shift cable nut.
However, it turns out that pliers and a 1/4" impact work even better.
The money I spent on that mill and tooling doesn't seem so bad after saving a bellhousing...
-Cole
Cole2534 is offline
Old 03-18-2013, 08:55 PM
Nice work. As far as the machines, better to have them and not need them than need them and not have them. My Bridgeport has paid for itself many times over....
mallatt442 is offline
