Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
painting a heat exchanger >
Old 02-17-2009, 06:24 PM
Default painting a heat exchanger
Hi,
I have a new copper exchanger that needs to be painted . I was thinking of using self etching primer and then painting it. Is this a good way to paint copper? Thanks
alecsammy is offline
Old 02-17-2009, 08:53 PM
Neno the mind boggler
glassdave's Avatar
I've never actually used it on copper but would certainly think that should be fine. I tend to lean toward ppg's DP epoxy primers though. What color are you spraying it?
08 OPA High Points Champion
glassdave is offline
Old 02-18-2009, 10:10 AM
Lakeside Restorations.com
Commercial Member
LAKESIDE RESTORATIONS's Avatar
If you are just going black you can shoot it with a spray can of merc's grey primer & a can of the phantom black drive paint. Its cheap & works well.. Jamie
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
TRL505
Fountain
0
07-18-2007 06:47 PM
UNSANE
06-27-2007 08:18 AM
ZP\'d
2
06-27-2006 12:40 PM
raynman
3
05-13-2006 06:23 PM
Quick Reply: painting a heat exchanger
