Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
thickened epoxy or rage gold for fairing >
Old 06-27-2012, 06:04 PM
Neno the mind boggler
glassdave's Avatar
Originally Posted by Glassic R.T.
Not trying to stir the Pot , and this is just a reminder ......... 3M filler should not be used with any Epoxy systems considering there is p - 77 made by Adtech , that is good above and below the waterline / sands easy , and can be used on Epoxy .
RT, you are always trying to stir the pot. . . . see post #2 already covered that lol. Dont much care for epoxies on smaller jobs. VE's the way to go and its best to scarf out any hole above a half inch or so. I scarf out everything any more and cap the repair with CSM.
The AdTech stuff rocks, I like the 861 ultra fair. Whats the advantage with 77?
Hey did ya make it out to Tawas? was lookin for ya. We had a great time for sure. Cat Can Do was there and runnin good.
08 OPA High Points Champion
glassdave is offline
Old 06-27-2012, 06:14 PM
Just , a quick mention , and that is ..........if you are going to purchase a filler be sure to get a protuct that is good above , and below the waterline .
Glassic R.T. is offline
Old 06-27-2012, 06:45 PM
Dave , very big difference in the way we both do things considering i never use Poly or Vinyl for any type of repair ( Small or Large ) which boils down to using only Epoxy on my end , and Dave , i know you have already covered that subject but if you read my post #10 , i mentioned that this was only a reminder , and the main reason for using P-77 is ........ because it is compaible with Epoxy / along with being Heat resistant which in my opinion is a better product to use . Dave , to answer the rest of your questions about Tawas i will give you a call considering i was only 40 to 60 min away ...
Old 06-27-2012, 06:48 PM
glassdave's Avatar
cool deal Artie . . . i mean RT
gimmie a call
Old 06-28-2012, 06:21 AM
rchevelle71's Avatar
gimmie a call
I thought so
rchevelle71 is offline
Old 06-28-2012, 07:28 AM
Pirate of the Chesapeake
Fenderjack's Avatar
Hey have you guys ever tried mar-glass,made by marson .It is a short strand filler,water proof filler.I have used this on Hundreds of jobs holds great under water and above.Little hard sanding but I use it as a base before a finial filler.JOHN SR
Fenderjack is offline
Old 06-28-2012, 07:41 AM
Used similar stuff above the waterline, not saying it cant be used below, just havent done it myself. For below the waterline, I believe I would use glass for the big stuff, thickened resin, or a marine specific filler such as 3m for the final fairing, but that is just me.
Old 06-28-2012, 05:30 PM
lol
hey wait a minute isnt that like a five gallon kit? Bringing your cost to what? $89 a gl? . . . . I win at $140 a gallon
To tell ya the truth there a place in Detroit called Michigan Fiberglass and they have an in house brand of snow white vinylester fairing filler i really like. Stuffs amazing, its weird it goes on thick and cures hard as a rock but for some reason still sands easily and is very easy to level. I try an grab a gallon or two any time i am up that way.
lol is there any other way to get it ? i only needed like 2 gallons but i don't think they sell it in that amount?
ridefast77 is offline
Old 06-28-2012, 06:20 PM
glassdave's Avatar
Actually no, some of those things are fives minimum. Corebond is another tough one to get. I am setting up a marine specific supply shop geared toward all the do-it-yourselfers and convenient quantities is one of the things i am working on. Man that sucks if you had three gallons of that stuff turning with no place to go.
Old 06-28-2012, 06:34 PM
lol tell me about it, ill use it for somthing more then likly in my motor bay. then it will be as slick as the outside what will be nice. marine specific supply shop, awesome!! i like the sound of that.
