k planes for 292
Very well! The F1 single big block won the national championship, so that says something about the hull design. The 292's available to the general public are only available with twin small blocks. Mine has twin 6.2's. It is a bit tail heavy, but the upgrade to K-Planes helped a lot. It has a 24° deadrise V, twin steps, and is heavy (7500 lbs dry). This is a great combination for rough water handling and speed. The most HP you can get stock is 640 (twin 320). The hull can probably handle twice that!
filler cushion
tony
Registered User
