Who's running a #6 in a single engine application
#62
Thanks for the good news, I am glad that it is working out for you so well, that is where the transmission is going to go in the standoff box...
#63
Very cool. I didn't even know anyone was offering a standoff box to hold a trans for a six. Is the box an off the shelf part, or did you custom make it? This seems like a great idea for the smaller boats, with less engine compartment space to work with.
Darrell.
#64
Redline, you stated that the Xpower wasn't going to work. I'm just curious to what were the problems they had with the single engine cat set up? Was it stability, getting on plane or?????? It seems like a great drive, but I simply do not know anything about it.
Darrell.
PS: sorry for the bold type. Not sure what the hell I did there.
Darrell.
#65
Weight shouldnt be an issue but it may make the boat handle a bit differently. JC went from a bravo to a 6 and mine always had a 6. He can comment on differences. Just add some more power so compensate for the 200 pound increase. No biggie. I will never own a go fast bravo boat.
My only issue was drive height and I tried a bunch of diffreent spacers and should have left it alone. Was tinkering with trying to make my 6 a true surface drive and it didnt work. Went back to original set up when I bought it. Props are way more expensive and I would ONLY go with a right hand rotation.
There is a cat guy here from out West running a 26 or 29 DCB with about 1400 hp I bought a propfrom that has done a ton of R&D.
Plus the cool factor is major
#66
Darrell.
Darrell.
#67
#68
Quote:
Originally Posted by check300
I am using a #6 in a single v-bottom. We did not move the engine but instead put the transmission in a standoff box. I wouldn't change a thing.
Here is Check300's set up, runs triple digits too
As for the box it was Designed by Tom Earhart, and he had BAM build it, BAM, had Stellings Marine build it now we have have Stellings Marine Extension boxes.
Now you know the rest of the story
So if your order your Stellings Stand off Box you will have to make a few adjustments to the flange for clearance.
The early boxes like this one pictured were all hand fabricated
Now they are all cast.
Jon
Jon
#69
I will disagree on the weight not being a problem. I have owned a few cats 24 and 25' They were very sensitive to extra weight hanging off the back. I was running twin 2.5's that only weigh 350 lbs each. Adding setback changes the center of gravity a lot. Adding just a few inches of setback on a outboard boats makes big chenges. You are adding about 12 inches with a box. You will also have a 100 lb transmission and a 350 lb drive to the back of the boat. I have noticed the difference in how a 40' cat will ride with the engines mounted on the transom or moved forward. Big differences. The tail heavy boat will pop the nose up every time you hit a wave. Can be very scary.
Is there no way to move the engine forward?
#70
