Do Drive Showers Really Cool The Oil? >
Old 04-01-2012, 08:21 PM
  #61
Originally Posted by Expensive Date
I did not bend one but I spent 15 minutes blowing little pieces of wood out of mine after that run.
when i ran the imco cap style i always had sticks and debris stuck in the inlet, on the simrek i have now they have dividers in the intake portion so anything that gets through that opening will flow out without clogging, has not clogged up yet
blownhammer2000 is offline
Old 04-01-2012, 08:43 PM
  #62
Expensive Date's Avatar
I never had a problem before, the run we both did was like running in liquid sawdust. it was right after a hurricane. Got home and found this, it did not want to come out had to use a small drill bit then grab it with a pick.
Expensive Date is offline
Old 04-02-2012, 08:32 PM
  #63
Attachment 471995
wow, thats crazy! i can't believe you didn't have any temp issues with that
Old 04-02-2012, 10:11 PM
  #64
Never even knew, the other side was open plus both sides. . There was not on scratch in the prop, got lucky on that one.
Old 04-03-2012, 01:03 AM
  #65
Originally Posted by KachinaShadow
So how ya gonna know if you're goin' any faster
Why would they have drive showers if they did not do good?
mcprodesign is offline
Old 04-03-2012, 08:10 AM
  #66
Why would they not come from the factory if they were necessary?
thirdchildhood is offline
Old 04-03-2012, 08:46 AM
  #67
Knot 4 Me's Avatar
Formula supplied them from the factory on the larger SS boats with bigger power and Bravo III drives.
Knot 4 Me is offline
Old 04-03-2012, 08:54 AM
  #68
Careful with those cap style drive showers. Make sure you use Red Locktight on the bolts. I had one on for 3 seasons and out of no where the drive cap bolts loosened up. Of course it happened at full speed and took the whole drive out. Need less to say in this case the leaving factor seal would have been the better solution.
JBoat is offline
Old 04-03-2012, 12:30 PM
  #69
Dean Ferry's Avatar
That's the great thing about the Simrek Halo's, only 1 bolt, Locktited in and no holes to drill. My XR's have the finned top cap, and I had to use a Halo, which was my 1st choice anyways.........
Everything is for sale @ a certain $$
Dean Ferry is offline
