If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Registered Mate 229's Avatar
    My Boats:
    1997 Fountain, 27 Fever
    Join Date
    Feb 2001
    Richmond VA
    38 SCweighs 9500lbs as opposed to 38 lightning at 8200lbs. Call Marty Boesinger at Fountain, he is the rigger and always willing to help with setup info, props, trim etc. 24's sound a little small for those motors.
  2. #12
    Join Date
    Dec 2000
    Flemington, N.J. U.S.A
    Well , we didn't get to figure it out .
    The weather was bad and we only went out once and had 2 small kids on board sleeping !
    Maybe next week. I am sure it isn't trimmed right ,and I would think it needs bigger props . The boat runs realy well and he is happy with it as is but I know he would be even happyer if we got it dialed in right !
    Since there was no way to do this test , I didn't pay much attention , but I think his indicators start at 1 and go to 7 or 8 is that normal on a fountain ? Most i have seen have negative and positive numbers ....... Thanks
  3. #13
    Registered Fountain38SC's Avatar
    My Boats:
    38 Fountain SC
    Join Date
    Jan 2002
    Cincinnati, Oh
    Been there done that. Assuming this is a sport cruiser, I can help. It sounds like he's going through the same progression I went through with mine. Started life w/ 502 MPI's then 510's with 250's on top now 545's w/ 10-71's, Whipple chillers, dry stacks and BMax drives.
    Trim the boat and then trim some more. Depending on the year hull and drive setup, I would think 6 is still deep - probably 7 plus is the trim answer but I don't think that's where the problem is. If he's around 600hp, the boat changes from a slug with its nose in the air to a performance boat.
    I'd really need to know how the boat is setup before I could give a better guess at the problem. pm me your number - i'd be glad to help.
  4. #14
    Mad Hatter
    Why the 4 blade?
    Originally posted by boot
    Fountain HAD 502's , with 23 mirage ,ran high 60's.
    Now has 510's with merlin heads , 250 blowers etc., and and runs around 70 with 4 blade bravo 24's .........
    Something is lacking ..........
    Mitch is getting at something here.
    Why the change to a four blade???? Did you change the x? If not then he has no need for a four blade. He's getting to much prop in the water. Go with a three blade and I bet you will see better gains. I'm making the switch right now.
    Turning a 27 4 blade topspeed 78.7 on GPS at 5350rpm
    Turning a 30 4 blade topspeed 80.6 on GPS at 5000rpm
    Turning a 25 3 blade topspeed 79.1 on GPS hitting the rev limiter.
    Right now I'm looking for a 27 or 28 3 blade to try.
  5. #15
    My Boats:
    38 Fountain SC
    Join Date
    Jan 2002
    Cincinnati, Oh
    If this is a sport cruiser, getting on plane is very difficult with 4 blade 23's. With full tanks it is almost impossible. Full the boat is going to be 11,000 plus. I
    agree that he has the wrong prop but I think there is sonething else going on.
    When I had 650's I was spinning lab 26's in fresh water and 28's in salt but I'm not sure that the prop is the entire problem. WIth this power and 24's, he should be spinning around 5500 and running upper 70's on gps.
Similar Threads
  1. Drive not trimming out
    By MILD THUNDER in forum General Q & A
    Last Post: 07-07-2008, 08:29 AM
  2. Trimming your fountain?
    By Racerngr1 in forum Fountain
    Last Post: 05-13-2008, 08:30 PM
  3. Trimming your drive on a 28
    By VelocityRick in forum Pantera
    Last Post: 04-25-2008, 05:54 PM
  4. Trimming the drive?
    By RazorsEdge in forum Superboat
    Last Post: 05-19-2006, 06:48 AM
  5. B1 not trimming up as far as it should.
    By Steve_H in forum General Q & A
    Last Post: 07-24-2003, 09:56 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
