Any 6 liter ford diesel problems ? Exhaust leaks common ???
Re: Any 6 liter ford diesel problems ? Exhaust leaks common ???
Glad I'm not going crazy ! I noticed that it is REALLY BAd with the heat or AC on now ..... I actually get a sore throat in a matter of minutes from the fumes .
I left this truck stock as the 03's were suposed to have so many problems . I never really did except for a bad idle . Now I have faith in the truck ,but it's time to get an 05 . That one is getting tweaked for sure ! I've been too long without power !
As many trucks as I work on everyday , I am surprised I have only found this twice .
Thanks for the info guys . I just hope the dealer can fix the problem without causing another one ! You know how they are .......
Boot,
Which dealer is it going to?If it's Flemington I can keep an eye out for you.
NJSONIC
You replaced my axle on my white Myco. (a freind of Grant's)
NJSONIC
My father has a 6L and has had it back to the dealer 12 times. They have no idea what is wrong. It has 11,000 miles on it , It smokes bad when you start it and will not respond to the throttle until you have driven it at idle for 5 miles or so. The dealer has changed lots of parts, it sets in the lot with him driving a rental at fords expense. Trying to get ford to buy it back.
Carney,
Ford has a book that shows all the common wiring pinch and chafe points in the engine compartment of the 6.0 liter trucks. Your dad may have a bad wiring harness. A friend of mine has been working on fixing a no start problem on a F550.The truck is getting a new engine wiring harness.Hope this helps
Boot,
If your bring your truck to Flemington. Ask to have Oren work on it. I spoke to him about your problem and he as fixed other trucks for this problem.
Boot,
KN
4
01-10-2008 08:12 AM
czy40p
4
06-21-2007 05:49 AM
Jamie Bowman
16
08-19-2005 12:00 PM
boot
12-10-2003 10:02 AM
