Mesa's Baddest Turbo Power
Re: Mesa's Baddest Turbo Power
I bet you can pick those up right down the street at the CarQuest, right?
believe it or not it is a standard size item I'm working with and it can be purchased from the manufacturer and shipped from one day to the other. As far as service life I've had them in drag racing engines for three seasons reusing them and unlike a conventional head gasket they can be reused with out risk of not resealing this is in Pro Import Racing engines were my 3.0 liter engines are making 1600-1700hp . I feel this is the best sealing system being used in the world right now.
Originally Posted by Wobble
Are the water and oil passages o-ringed also?
Awesome power
Awesome power
Originally Posted by MESABALANCING
The water passages are sealed and head water and block water are isolated the block water and the head water never communicates
I'm sure its been done before, just I have never heard of it. If not, double brilliant!!
Not to mention the sealing advantages
Originally Posted by Bigyellowcat
finally something impressive, water that talks !! wasn't that in a movie, I think it was the Abyss.
On a more technical note, I see it took you along time to get a cam profile to work with a motor, head, and turbo combination that were designed way wrong. Didn't those engines come to you with the o-rings already done? Or did you design that part?
Tyson
Tyson
Yes we machined and modified the cooling system and machined the grooves for the nit. rings the rings were originally made for NASA we didn't design any of that the cam changes were to perfect the combo not necessarily because the cams were junk when we build something as radical and advance as this we want to turn every stone over and not leave anything on the table the engines start and run like a taxi car engine that you can take to the grocery store but when you roll in the throttle hang on they make crazy torque and HP these cams are all computer designed lobes and the profiles are very aggressive they open the valve with extreme speed and lay it gently on the seat to eliminate valve float with 440lbs of spring press on the seat to eliminate flutter at high boost levels also. We run two O2 sensors on the dyno for tuning only and run egt's in the boat and autronics O2 senor also remember these numbers haven't had race fuel yet. We're currently inspecting internals to trun the boost up with C16 we'll see how the O2's work then. All the power we've made has been on 93 oct and after I posted originally I found the boost gauge I have in the dyno room was off the computer read instead of 15lbs it was actually 12lbs were we made the power
Originally Posted by NOBODY
I'm pretty sure those motors came with the cooling system separate between the block and heads. I know some of those motors came with the nitrogen filled combustion rings.
ummm ... yea ... just read the thread ...
