1982 38 scarab kamma
I have my eyes on this boat . The owner tells me it has stringer problems in the cockpit area is there a source to get drawings on the layup of this hull ?????? Has anyone had experiance in this area Pleeese Advise Thanks Ralph
Lakeside Restorations.com
Commercial Member
Re: 1982 38 scarab kamma
It can be fixed.. We could do it for you but it is very expensive to replace stringers, frames, transoms etc... Be sure you know what you are buying before you take the plunge.. You could spend more on repairs in some cases than what the boat cost you to buy it...
Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
I once owned a 1981 377 KAAMA SE by Wellcraft. The transom was wet, and rotted and I had to have it replaced/repaired. I ended up ripping the whole boat apart because of the rotted stringers etc, just kept going on and on. I didn't have the time to go through all of that so, I found a buyer from Canada who bought the boat in 1999.
I bought my 1990 32' Active Thunder after that and I ended up having to replace the transom and engine stringers in that as well, but it wasn't as near as bad as the Wellcraft---still no party by far, but my A/T is better now than it was built when new. ALWAYS have a marine survey done on the boat and water test if possible---Make sure you do some fact finding and KNOW what you're getting into BEFORE buying the boat....I don't care what anyone says! It's a whole new world in this boat scene stuff and it seems I have been too trusting at times. I have learned a ton about the boating industry and the people involved with them both good and bad---live and learn.....and STILL learning!
Whatever you buy/decide on I hope it goes well with you.
Mark
Mark
phughes69
Scarab
2
05-23-2008 11:52 AM
