who wants to lend me a 496ho scan tool >
Old 08-28-2006, 09:44 PM
Default Re: who wants to lend me a 496ho scan tool
While I was digging around flushing the oil cooler (to make sure there were no pieces of water pump impeller stuck there) I did notice a "new" sensor in the oil cooler that I had not seen on any of my previous engines (mostly carbed and EFI 500's). Thought maybe that was for water pressure, but wasn't sure. When you say "open" I assume you mean "infinite" ohms, not "0" ohms, on the meter, right ? .... with engine running, or with engine off and no pressure? It would be rather hard to check with engine running, given the tight space to work in on my current boat. I will ask technician to make sure they check that sensor, tomorrow when they scan my 6.2 MX. One of my 500 EFI motors did this 2 beep syndrome and that motor doesn't have a water pressure sensor, just water temp, oil pressure (which is just an open/close switch), drive oil bottle (open/close switch), and low voltage for the alarm system ... unless the computer develops "issues". By the way, my 6.2 just hit 126 hours, the port motor has 128 hours and it is just fine ( for the moment, anyways )
bob_t is offline
Old 08-28-2006, 11:12 PM
Masher touches my
Outdrive1's Avatar
See my other post, the motor I'm refering to is a 6.2.
http://www.offshoreonly.com/forums/s...d.php?t=139039
Outdrive1 is offline
Old 08-29-2006, 05:08 PM
Member #9
hp500efi's Avatar
I just ordered the Diacom software to do my own investigation. I should have tomorrow and will scan and report.
Member of the Liquid Jungle
hp500efi is offline
Old 08-29-2006, 05:46 PM
Toxic FORMULA
mopower's Avatar
My cousin had the same alarm on his new Fountain with 525efis. Turned out to be a bad sensor .
mopower is offline
Old 08-30-2006, 10:52 AM
Which sensor?
bcolmsted is offline
Old 10-16-2006, 10:20 AM
Still fighting alarms...Went out for 2hrs of solid running with no problems or alarms..then the 2 beep every 60 seconds came back, but this time when i went up to 4000 rpms the alarm went constant..Gauges all normal and no safe mode. thot i had it fixed when I cleaned connector on sensor at the seawater pump..apparently not. Anyone know what a new sensor costs? and it I take it to the shop for computer hookup will they be able to make a diagnosis if its not acting up? A new impeller was installed a couple weeks before this started..But I found all the pieces of the failed impeller and the pump was not scarred..Temp gauge never exceeds 175.
anyone? tnx
Old 10-16-2006, 03:36 PM
Dave_N's Avatar
They should be able to retrieve the Freezframe memory and see what the issue was/is even if the problem is not happening at that moment. The sensor is about $100.00, so get it scanned before you start throwing money at it.
Dave
Dave_N is offline
Griswald
4
07-22-2007 02:09 PM
jhoward
07-08-2007 11:26 PM
jayhawk261
Grand Lake/LOTO/E-Dock
0
04-07-2007 12:09 PM
Reckless32
3
08-23-2006 05:54 PM
mars
5
02-18-2006 08:12 PM
Quick Reply: who wants to lend me a 496ho scan tool
