CMI 496 Sport Tube Install >
Old 01-07-2007, 05:47 PM
Default CMI 496 Sport Tube Install
My question is I have a 496 with Corsa diverters and a Y pipe and was wondering about the install.
I would like to keep my same diverter set up, anyone know of installs with Corsa diverters on a stock 496 Mag/ Bravo 1?
Also, there is a lot of talk as to what a challenging pain they are to install, in what regard exactly. It seems rather straight forward if you dont rush it, then again it is never fun working wedged into the bilge???
Thanks,
R-
davis777 is offline
Old 01-07-2007, 07:53 PM
Default Re: CMI 496 Sport Tube Install
Thanks,
How would we determine the proper tails?
davis777 is offline
Old 01-07-2007, 08:18 PM
My Corsa diverters are:
Corsa Part# 81000
Diverter Valve Assembly - Polished w/ Vertical Shaft
davis777 is offline
Old 01-08-2007, 12:52 PM
30 outlaw 2005's Avatar
I have a 496 twin setup with CMI headers and the Corsa diverters. The only problem that I had was I had to cut my Corsa diverter down tube one inch because it was to long and would not bolt up. If you need any other info feel free to PM me.
Rob
30 outlaw 2005 is offline
Old 01-08-2007, 07:08 PM
crayolacrazy's Avatar
I just finished installing mine . My engines are whippled 496,s with corsa . There was not a lot room in a 33 outlaw but there in .And we made our own computer brackets out of stainless, it was a rough job
crayolacrazy is offline
Old 01-08-2007, 07:27 PM
Any chance you have some good Pics of the engines?
davis777 is offline
Old 01-10-2007, 08:12 PM
Pics of my engines are on Baja forums 800 plus hp
Old 01-12-2007, 05:18 PM
Originally Posted by Pantera28-650HP
Your first time will take a couple days. The kits are pretty straight forward and have nearly everything you need to relocate your accessories.
We have a couple standard 496 sets in stock and would just need to get you the proper corsa tails to match your system. Let us know if we can help.
Kirk
Ateco Engine and Dyno Shop
Your CMI Source
quit hijacking your prices are to hi
Old 06-20-2011, 09:39 AM
I know this is an old thread but has anyone else had an issue with the tails not lining up? It seems the angle of the sport tubes is much greater than the stock manifolds and is roughly 2" lower than the tips on transom. What are my options to get this to line up?
Baja_man is offline
teaguecustommarine
New Products and Member Discounts
18
01-31-2008 11:23 AM
teaguecustommarine
1
02-28-2007 03:31 PM
teaguecustommarine
2
09-13-2006 03:32 PM
hammer_34
10-12-2005 12:53 PM
Quick Reply: CMI 496 Sport Tube Install
