SUPER CHILLER plumbing
#41
One thing I forgot to mention, you should have pressure gauges on the intercoolers. I hook them up in the intercooler strainers. I figured the strainers would be the restriction. I have #16 all the way from the pickup, through the strainer and them it splits into (2) #12's into the intercooler. (2) #12's out of the intercooler go into (1) #16 to the transom mounted dump. The strainer has a 3/4" adjustable pressure relief that dumps out the back to. I have it set about 15 psi.
Eddie
Eddie
#44
On my Cat can I come off the same the same pickup or sea strainer that supplies the engine? (T-off line or come off the sea strainer) Or do I need a separate pickup? On my old setup on my Baja I went through the intercooler, to oil cooler then engine. You can see the custom intercooler in my avatar. On my Cat I have #5's with a 2 stage pump from transom pickup.
Randy
Randy
#45
Randy
Randy
#46
Randy
