Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-09-2009, 10:04 PM   #11
1997 Checkmate 283
Quote:
Originally Posted by PAST DUE View Post
the sensor wires you see or the sensor you see is a e.g.t sensor not a o2 sensor whipple does have some parts for these units i have had both of mine rebuilt in the last year ( one from failure and one to keep from failing) they can put there entire rotor pack assy in the old housing if is't not hurt. also have entire manual if you cant get it from any one else.
Past Due, if you could make a copy of the manual or scan and email it I would pay all expenses. Did you have yours rebuilt at Whipple? When I called them I was told they have no parts left for the side mount model. What failed on yours? Did you replace all internals or just what failed? Are you using the piggyback computer or a reprogramed MEFI 3?
Thanks.
Inspector is offline   Reply With Quote
Old 11-10-2009, 05:42 PM   #12
BOAT DOCTOR INC
PAST DUE's Avatar
1997 FORMULA FASTECH 312 whipple charged 454 mags imco 2 in shorties
i will try and make a copy for you i had 2 copies from the start i will try to find one of them. i did send mine to whipple and they put their complete rotor pack (their description) in my housing which replaced all internal parts and had to send the front billett plate with the charger at the same time to have some machining done on it as well to make it all fit. All i know about the failure was the rotors started rubbing against each other and the engine started loosing power and i let off and shut it down i never could get whipple to call me back and tell me what happend. i did send my other unit in the fall of the same year. to keep it from failing .
whipple said the new rotor pack was" better in every way " than the old unit. i have been using the piggyback computer however it is being removed as we speak and will be going to mefi 3 system with my rebuilds.
PAST DUE is offline   Reply With Quote
Sponsored Links
Old 11-11-2009, 12:17 PM   #13
Offshoreonly Advertiser
Young Performance's Avatar
Quote:
Originally Posted by Inspector View Post
OK, here is the deal. I have a twin engine boat and one whipple side mount set up which I have never installed. There is no history on this set up so I would like to disassemble and inspect it prior to use. Also, I would like to understand the operation of the piggypack PCM before I install it or go to further expense of updating to a MEFI 3 and a reprogram. The piggyback PCM appears to be somewhat sophisticated as there is an O2 sensor attached (so I feel there is value in investigating it's operation). I am currently shopping for a second unit but am starting to wounder if I am wasting my money if there are no service parts available for them. Can anyone identify a common weakness of these (although I do not believe there is much to them... housing, rotors, bearings and gears)? So the bottom line is I am looking for a manual and the availability of service parts for the side mount set up. Any insight would be appreciated. Thanks.
The best bet would be to go to a Mefi 3 or 4. If the piggyback ecm evers go out, you can't replace it. It's job is to turn on the extra 2 injectors above the blower. The egt probe is there for protection in case the egt's get over 1500 deg. It all works pretty good. The blower can be rebuilt if anything goes wrong with it and they do have better parts for it now. The ecm can't be fixed or replaced. You will be just fine to put it on like it is. However, it would be better to replace it with a Mefi 3 or 4. Good luck with it.
Eddie
True, Custom EFI and Carb. engines from 500 to 1500 HP. Also specializing in outdrive upgrades and repair, custom rigging and fabrication, we can handle all of your performance boating needs. See our entire engine line at www.YoungPerformanceMarine.com Contact us at 615-216-7449 or youngperformance@comcast.net
Young Performance is offline   Reply With Quote
Old 02-04-2010, 12:39 PM   #14
1993 29' Profile
Manual and Pulley
Wondering if anyone has a installation manual and v-belt crank pulley for the whipple sidemount for sale. Thank you
KS IMP is offline   Reply With Quote
Old 04-03-2011, 02:55 AM   #15
1986 Trojan 10 Meter "dirty connection", 1980/2010 Banana 24', and a 29' Scarab
Yes, I would also like a manual, will pay all expenses & time to send it to me. thanks, chad
Trojan-man is offline   Reply With Quote
Old 01-05-2012, 02:32 PM   #16
Post Manual
Is there any way I can get a copy of that manual. I just got a used one and plan to put it on a 7.4 in my 97 k3500 Dully. Whipple has been no help.
THANKS ROBIN
COONDOG96 is offline   Reply With Quote
Old 01-12-2012, 08:21 PM   #17
blown powerquest lazer
did you get a copy of the manual?...dustin is a nice guy but he's almost denying those sidemount ever existed...dunno why,as they were good lil blowers.
pqjack is offline   Reply With Quote
Old 01-12-2012, 09:38 PM   #18
01 Glastron 225, 2000 Advantage Victory 27' 575hp
sidemount manual
I have a copy of the manual stored on my computer. Anyone wanting a copy can pm me their e-mail address and i would be happy to send it. I have both the 454/502 mag and the manual for the HP500
I also have a 454/502 mag whipple setup that I am considering selling as I don't have enough room on the front of my engine to install it. I have an extra manifold, bigger injectors, MEFI 4B ECU, wiring harness and more. Serpentine belt crank pulley.
snapmorgan is offline   Reply With Quote
Old 01-19-2012, 04:08 PM   #19
Can you email me a copy of that manual?
j_pitts@hotmail.com
justinp20012500 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
