Zero Cavity
Charter Member#350
Went out testing on Saturday and found that the fuel pump regulator was crack and leaking fuel.
On Sunday we got it fixed and now the port engine is acting up and today we will change to the original ignition box and test again.
So far the drive is GREAT:
1) I go on plane faster and easier with no need to use the trim tabs.
2) My children are save now when we go to the beach , they now go on board through the drives.
Top speed is not there yet and we will try bigger props in two weeks.
DR. Santiogo..........
What did you do with the old #3's?
The yellow would look pretty trick on my purple transom. Plus I keep having problems with the TRS not hold power.
