prop question
labbed 27's mirage props
Dave send me your contact number and best time to call you,and I will do my best to get you fixed up/Darin
Houston Propeller on Kuykendahl rd
I forgot to tell you , I have to trim almost all the way down to get it to 50 mph if i trim up the slip skyrockets, some poeple are telling me to get a mirage because of the larger diameter
will let me trim up, got any Ideas
prop/TOPDJ
When the prop arrives, I will call you,also Iron man, might just be right? we will see what can be done with yours first and go from there .none the less the prop will be alot better and if you come across a 19 mirage plus to try, It would be worth it to try. Talk to you later /Darin
new numbers 2 people 7/8 tank
4600rpm 52mph
4000rpm 44mph
3600rpm 38mph
still cannot trim it out , blows out easy
4600rpm 52mph
4000rpm 44mph
3600rpm 38mph
LOAD CHANGE'S SPEED
WE HAVEN'T WORKED THE PROP YET,but as you can see how the load factor really changed the numbers, have a good 4th JULY AND we will look for the prop after the big BANG!
yes your right and I just found that I read the tach wrong
Im running with 1/2 tank 2 adults a 4600Rpm
52.5 mph gps on pretty smooth water
the silent choice I have , mine is the reverse type No power = thur hull, It helps a lot to plane quicker with it on or thur Hub
then once on plane turn it off and the diverters open for a gain of .7mph
I'll be leaving them vent holes, seem to be good for the holeshot
when in thur hub mode
the numbers after Darin worked this used prop back to shape
OLD could not plane at low speeds
New I can plane all tha way down to 28mph
Old 3000rpm 30 mph
new 3000rpm 34 mph
Old 3600rpm 38mph
new 3600rpm 41.5mph
old 4000rpm 44mph
new 4000rpm 48mph
old 4600rpm 52mph
new 4500rpm 53mph*
improved lift and ride.
now I just need more horses to turn a little more RPM
Old 3000rpm 30 mph
new 3000rpm 34 mph
Old 3600rpm 38mph
new 3600rpm 41.5mph
old 4000rpm 44mph
new 4000rpm 48mph
old 4600rpm 52mph
new 4500rpm 53mph*
