Darts flow well out of the box. There's always room for improvement but you will net "less" of an increase porting the darts than you would by porting the stockers.
Porting (properly done) will always net an improvement.
In your case, though, you are at a point (420 hp) where there are no "silver bullets" to gain a huge amount with a single change.
A 4mph increase from where you are will require a host of complimentary changes (compression increase, head porting, cam change, and spinning well over 6,000 rpm most likely).
Additional cubic inches (via a stroker kit) or a blower would be two feasible options for you. Be aware, though, that if you decide to go with a blower, you may need to lower your compression ratio depending on where it currently is (I'd take a wild stab at 10:1 with 420 hp).
Changes in weight distribution, shorty lower units, extension boxes, and labbed props are NON MOTOR alternatives for more speed.
Good luck.
I see London, I see France...
