Merlin ovals and 540's??
Dyno- I don't think its nuts, I think a guy could have a SWEET running torque monster with that combo...in fact, if you build it to limit at 5200 those heads would be closer to optimum than cw would indicate. My choice though, just dreaming, would be the Dart 265 ovals with just a little work
Check out the AFR 305 "CNC Chamber" heads. Not the CNC Ported. It even outflows their 325 "As Cast". The 315 CNC Ported is only about 4% better than the 305 CNC Chamber head.
I think a 265cc is to small for that many cubes. I am in the process of building such a motor and am trying to decide which way to go. I am wondering if 305cc is to small. The numbers look good though.
www.airflowresearch.com
The Merlins would be great torque monster builders on the 540, but for best top end some 325's would work better. Sure there will be a slight give away in the low and mid range, but it will still be good with 325's and top end will be better.
Charter Member #655
I think becouse I have all the components from my 454's already and want to use as much as I can I'm going to build some 496's and save some $$$
If your boat has a sail do you ride a horse to the ramp?
Charter Member #655
bought another block Saturday, so now I can get started!!!now I need some overtime to pay for it!
Hey Dyno,my friend ran a 540 with small port merlins in a 30 ft single engine boat and goes about 85!! Big hyd cam,cmi's 950 carb,Imco bravo,ran nice good luck Tripps
Charter Member #655
Thanks Tripp! I'm going to build a couple of 496's this time around I have the blocks ....540's next time!
