TRS - how to tell the difference between Merc and BW trannies?
Re: TRS - how to tell the difference between Merc and BW trannies?
The really early ones that had electric solenoids moving the shift lever on the transmissions had the delay you are probably aware of, but it wasn't the tranny's fault.
God, am I old! They haven't used that system decades!
Newer style Merc pump has larger keyway, it will adapt to both style input shafts by using the proper key.Smaller keyway pumps were more likely to crack,newer style ones are much better.These newer pumps have been out for a long time now.
Originally Posted by thayes11
I see what looks like two electric solenoids above the transmission, that I hope is my delay from Netural to Fwd. The boat is winterised so I cannot get into the Engine compartment now. Can I remove the electric solenoids, if so How do you go about doing that ?
Charter Member #232
Originally Posted by Edward R. Cozzi
I think there's a kit to convert to cable shift. Is yours that old?
Jon
Put your best foot forward!
