Diary of a mad man part 2
#101
#102
I would think it works just like applying vinyls....? Tape it in place, then peel the backing out from under it one half at a time...? Yes/No? Genuine question. We are considering applying SeaDek to our floor, and don't want to farq it up.
Awesome build, BTW. I, too, have a thing for the minimalist look, and the greys have become one of my favorite colors.
How much HP? If you stated, I missed it. Are they really 11.2" deck blocks? I didn't even realize that was a thing.
Thanks. Brad
#103
Tomcei,
Thanks. Brad
Thanks. Brad
#105
Tomcei,
Thanks. Brad
Thanks. Brad
Edit: Actually I just realized you have fabricated tunnel rams! Just painted grey. Nice! The 1x4 reducer really annoys me but I’m assuming it will be easier to make it idle and mid range tuning.
#107
yes, they are 11.1 . google it up and you will find them. and you are correct we fab'd the intakes. I agree with the goofy single. I can easily change the top and run twins but this is what i landed on to start this adventure. I asked the same questions about fuel distribution and was assured it wasn't going to be a problem. Plugs and O2 senors and exh temps were good.
I have not weighed it fully rigged out but i am anticipating a little over 10k lbs. no top speed predictions.
#108
So, what are your numbers in the engines? Bore, stroke, rod length.... You can build a 632 with a 10.2" deck, so I'm curious how you made use of the extra inch of deck height.
I, too, wondered about the single carb. To this layman, it certainly seems like have a carb feeding each of the two clusters of four runners would be ideal. Can't really argue with the results, though. It seems to be working just fine.
Again.... Awesome build.
Thanks. Brad.
#109
My original intent was to build 700 cubic inches but there were many unfortunate turns along the way, I had planed on a different crank and running 4 carbs but i had to go a different route due to some COVID forced compromises. This engine was being put together at the peak of the supply problems and my industry getting completely shut down. So...i honestly got tired of waiting for parts and saw my budget dwindling so i did a little down sizing to move the project along. I was constantly fighting scope creep.
i'll pull some paper work and see what we did.
Tom
Tom
