Looking For Pat >
Looking For Pat
Looking For Pat
Old 12-06-2005 | 01:07 AM
blaniac's Avatar
Default Re: Looking For Pat
Blane,
In one word: 'nicely'. Quite honestly it is a total hot rod.
Now, are those tix into the show or tix on a plane?
Pat
Already got plane tix today, just need show tix my friend
blaniac is offline
Old 12-06-2005 | 01:09 AM
blaniac's Avatar
Originally Posted by Steamin Rice
Blane,
Did you step up to the 33?? If so, congrats..
Greg
I have not, as I would plan on selling the SW first, but I am VERY interested in the boat and will be in Miami come February with hopes of seeing the new 33' there
blaniac is offline
Old 12-06-2005 | 07:59 AM
thunderdan's Avatar
I am not sure about the hull, but I am pretty sure it was blueprinted when it left the factory. It is possible that the hull now has something in it as I think it has spent most of its life on a trailer.
I know that Rick also experimented with the box on and off but did no see any change.
I would see the porpoising when I was at WOT, trimmed up. I would drop the tabs(they are still the big 380's correct) just a little and it would settle right down as I am sure you already know.
Good luck
Dan
thunderdan is offline
Old 12-06-2005 | 08:00 AM
thunderdan's Avatar
Blane,
Pat
I bet that 33 is going to run fast, and handle like it is on rails.
Old 12-06-2005 | 02:19 PM
blaniac's Avatar
You are probably right and I am thinking twin 625 Ilmors would be a nice package and setup for that boat or maybe Whippled 525's !!
blaniac is offline
Old 12-06-2005 | 05:16 PM
slboatdrinks's Avatar
Will let you know what it does with 525's in Feb. Should be in the low 90's.
slboatdrinks is offline
Old 12-06-2005 | 07:14 PM
ActiveThunder's Avatar
It's never that warm here in February.....
ActiveThunder is offline
Old 12-06-2005 | 07:15 PM
thunderdan's Avatar
I would think so. I bet it would dance in the upper 90's with 625 hp.
Old 12-06-2005 | 09:15 PM
Very funny FL boy!
Old 12-06-2005 | 11:50 PM
Good luck
Dan
Dan,
Yes the boat still has the 380 tabs on it. Rick (rsteiny) never did end up removing the box while he owned it, I did after I purchased it.
To remove the porpoising I have to use a lot of tab which scrubs serious speed and you still can feels it's urge.
What I'm looking for from Active Thunder is what do they recommend for my hull, slight hook, flat with no hook, etc.
I want to have some one look at it to see if this is what is creating my porpoising problem.
Thanks again,
Mike
Active Mike is offline
