Engine coupler >
Engine coupler
Engine coupler
Old 09-16-2009 | 11:45 AM
Default Engine coupler
On my 32 active thunder with 500 hps do i have to pull the motor to change the engine coupler.
rssteiny is offline
Old 09-16-2009 | 11:55 AM
ActiveThunder's Avatar
You could cut a very large hole in the transom to get to it.
ActiveThunder is offline
Old 09-16-2009 | 12:14 PM
THAT WHAT I WAS THINKING, BUT THEN WHAT WILL YOU CHARGE ME TO FIX THE HOLE
Thanks Pat
rssteiny is offline
Old 09-16-2009 | 12:50 PM
Thunderstruck's Avatar
I have seen it done in the boat. Take the drive off. Put a chain hoist on the motor (or let it hang on the front motor mounts, better with the chain hoist) take off the bell housing and change the coupler.
It ain't pretty and it ain't easy but it can be done if you absolutely don't want to pull the motor. By the time you get down to the coupler there aren't too many more connections that need to be disconnected to pull the motor.
Tom
Long time cult member.
Thunderstruck is offline
Old 09-16-2009 | 12:51 PM
Also saw a transom assembly changed without pulling the motor. Too much for me but it can be done.
Old 09-16-2009 | 12:55 PM
I am an honor graduate of the Boudreaux School of Mercruiser Marine Technology.
Old 09-16-2009 | 08:22 PM
What about big Marie?
509 SC is offline
Old 09-16-2009 | 09:12 PM
Marie is off running the crab traps sha!
