Leaking power steering fluid.....help >
Old 04-08-2012 | 07:21 PM
R Addiction's Avatar
AT Cult Member #3
Originally Posted by sleev-les
Where did you move to? Still up in PA?? My bday falls on a Saturday this year (21 July) and am going to try and get some locals (or fairly local lol) to raft up at Dobbins Island.... I know we were tryin' to get some of the fellow Tantrum owners to meet up last year
Still in Malvern, Pa. Dobbins sounds good, keep me posted.
R Addiction is offline
Old 04-08-2012 | 08:42 PM
I have been messing with the same piece all weekend. It is e "relief valve" for the zero fitting.
FuelinAround is offline
Old 04-09-2012 | 09:36 AM
Boat is going to MDG Performance on Saturday for full hydraulic upgrade and carb tuning....
sleev-les is offline
Old 04-09-2012 | 09:56 AM
AT Cult Member #3
You will love the solid feeling with this upgrade Scott!
Old 04-09-2012 | 10:45 AM
Aside from cost, I'm pretty psyched about the upgrade.. Im def more than ready for the summer
Old 04-09-2012 | 05:56 PM
REMEDY's Avatar
Forget the cost... It is a big safety upgrade! Especially with big power.
How bad does the engine roll at idle? I doubt you will get all of it out. It's a characteristic of carbs on big blowers... Rich-lean roll. Real pain in the ass to get it in gear. Some guys disable neutral safety switches and just start it in gear like it was a crash box.
REMEDY is offline
Old 04-09-2012 | 06:09 PM
I love that sound although I have never had to deal with it. Is it a pian to operate? Are we talking about a high surge then it almost shuts off?
My Addiction is offline
Old 04-09-2012 | 08:03 PM
AT Cult Member #3
Just drop it in gear when the idle goes low.
Old 04-10-2012 | 05:37 AM
It rolls to the point of almost dying. It has stalled on me when shifting into gear at the low point of the roll. If I leave a little throttle to it after the engine is warm and been running a while, it smooths out and is still under 900 rpm. Its not hard to operate otherwise. Im just not a carb guy and I figured I'd let Dave take a look at it and see if he can correct some of it.
Old 04-10-2012 | 06:34 AM
REMEDY's Avatar
It also helps if you have a locked out distributor and control the timing with a programmable ignition box. Such as a digital msd 6. If you have any mechanical advance in the distributor it will aggrevate the problem. With a digital box you can also put a boost retard curve in with a map sensor and run more boost... more power!!
REMEDY is offline
