big thanks to the cult at boyne thunder >
Old 07-16-2012 | 06:28 PM
wrinkleface's Avatar
Originally Posted by boatfreak
sorry you had the trouble and let's hope it's not that bad.
x2!!!
wrinkleface is offline
Old 07-16-2012 | 08:23 PM
rlj676's Avatar
Man that sucks. Still plenty to do up there for fun I hope.
rlj676 is offline
Old 07-16-2012 | 09:15 PM
I tried, sorry I was of no help. My wife tells me that all the time!
BlueOval is offline
Old 07-17-2012 | 12:26 PM
REMEDY's Avatar
Originally Posted by THE 288 KID
#7 exhaust rocker got out of alignment and the pushrod came out of the dimple and up along side of it. Replaced the parts and its still missing.
Might be done for the season dunno yet.
Sorry to hear your troubles Jordon. Hope you still had fun!!
Actually the reason the pushrod came out is because the valve stuck in the guide. The 525 has a small amour of reversion on 7 & 8 cyl at idle. That causes carbon to stick to the valve stem and eventually it will stick, causing the valve head to hit piston and bend the valve. Common problem with the 525, they all do it, usually between 250 to 300 hours. Also the exhaust flange of the head will probably be very corroded. You are still missing because the valve is bent. The valve springs merc uses are marginal at best further causing this problem. When I do the 525 cylinder heads I hone the exhaust guides for a little more clearence. I also use a looser valve seal on the exhaust side to allow more oil down the guide. Coupled with a much better spring and retainer package.
REMEDY is offline
Old 07-17-2012 | 12:55 PM
yep that's what happened to mine.
aabaroni is offline
Old 07-17-2012 | 01:26 PM
****. How much we talking here? $$$$
THE 288 KID is offline
Old 07-17-2012 | 03:20 PM
The audience is growing...
verbi69 is offline
Old 07-17-2012 | 04:55 PM
Yes drew (remedy) knows what he is talking about and knows more about heads and engine building than most anyone. Had him do my heads a couple years back.
(DONT LET YOUR HEAD SWELL THOUGH
rssteiny is offline
Old 07-17-2012 | 08:08 PM
Head is coming off tomorrow. The suspense is growing...
Old 07-17-2012 | 09:50 PM
R Addiction's Avatar
AT Cult Member #3
Yea Drew, For a button pusher, knows his way around an engine. he'll have plenty to do on his many off hours!
R Addiction is offline
