Ebb and flow; AT sales. >
Old 08-28-2012 | 03:37 PM
  #61
Originally Posted by 1980Condor460
I am with you there - I had a power issue so I didn't get to run it after the Shootout when it gets crazy. However, Wednesday through Saturday morning it was a wave crushing machine. We were a little late getting to the fun run and found ourselves in a lot of wash off of the rocks. I looked over at my co pilot and he was drinking coffee while we were running over 80.
What power do you have in yours to reach Mid 90's plus? I have/had a couple of dyno proven 630hp - XR drives - 31 4 blade bravo 1's and didn't quite see those numbers. I tried some 34 bravo 1's but they would blow out right before I could get on plane.
Merc 525s with Whipples and 5-blades.
ecstatic is offline
Old 08-28-2012 | 05:02 PM
  #62
boatfreak's Avatar
Boatfreak - who worked on your 34's? Nice power and impressive numbers. XR Drives?
BBlades did my 34s in an attempt to get me on plane. They put a ton of cup in them and in doing so pulled about 7mph off of them. I guess you could say they are a work in progress. These engines are originally Teaque 720s that spin crazy high RPMs. I was running 95 at about 6200 with 32 bravos before my rebuild. When Eddie got done with them they were chipped at 6000. They do have Teague Platinum drives behind them.
boatfreak is offline
Old 08-28-2012 | 06:03 PM
  #63
ActiveThunder's Avatar
I have a set of labbed Merc 34 bravos on the shelf. Used twice. Let 'em go for $1200.00. No negotiation.
ActiveThunder is offline
Old 08-28-2012 | 06:22 PM
  #64
1980Condor460's Avatar
Thanks Pat - I have a set of 34's. Sounds like I need to get my stuff back together then go to 5 blades.
1980Condor460 is offline
Old 08-28-2012 | 06:30 PM
  #65
Agreed. Before you pizz away a buncha money with Hydromotive, Bblades, etc., call me.
Old 08-28-2012 | 08:38 PM
  #66
boatfreak's Avatar
I kind of agree with Pat. The Hydro is good out of the box and will save you some money if you just want an everyday prop. The Bravo can't be beat for top end. Pat will say a Maximus cut down to 15" and if you want to spend the money he's right. I must say that after I've been through all of these props I wish I had a good set of Maxi's.
Old 08-29-2012 | 12:32 AM
  #67
REMEDY's Avatar
I have the original 32's that pat put on mine new... everything i have tried hasnt been as good. All the lapdancing etc. Hasnt done done chit. I turned these 32's to 5800+ two weeks ago in Narragansett bay in perfect conditions... but gps quit the first leg of the run... all i know is at 5400 its 94. Up there was the first chance in good water this year. Just wish i could have seen the number. I think ill just stick with these plain ole props!
REMEDY is offline
Old 08-29-2012 | 07:19 AM
  #68
Originally Posted by remedy
i have the original 32's that pat put on mine new... Everything i have tried hasnt been as good. All the lapdancing etc. Hasnt done done chit. I turned these 32's to 5800+ two weeks ago in narragansett bay in perfect conditions... But gps quit the first leg of the run... All i know is at 5400 its 94. Up there was the first chance in good water this year. Just wish i could have seen the number. I think ill just stick with these plain ole props!
94 @ 5400 is 14% slip with your set up that is proped as good as it gets.
rssteiny is offline
Old 08-29-2012 | 07:39 AM
  #69
I would listen to Pat on the Maximus.
laszlo01 is offline
Old 08-29-2012 | 08:05 AM
  #70
outriggers's Avatar
A GPS pic with a hundred would have been nice. Lapdancing? LOL, I think I know where I can get that process done at. Doug
outriggers is offline
