Used my Tantrum for the 1st time ! >
Old 05-02-2013 | 03:56 PM
  #61
just got off the phone with Pat , he gave me some pointers .
state1310 is offline
Old 05-02-2013 | 10:06 PM
  #62
I put a fuel tank last year. I stripped the interior myself and then left it to the pros.
SHORTFUSE is offline
Old 05-03-2013 | 08:10 AM
  #63
Glue it, tape it, dont fill up...and wait for the season to end. Is what i would do. If you cant fix it yourself with a case of beer and a weekend. Marine mechanics seem to be on a different timeline than the rest of us. yeaa boating broken/fixed/broken/fixed/broken
carrera1 is offline
Old 05-03-2013 | 09:53 AM
  #64
i like your style ! me and my buddy GMCHEVYTECH are going to start tear down this weekend . I'm pretty confident we can get the floor removed if necessary and repair/replace the tank . i know its gonna be a big job , but i cant see paying someone $5k or more to do it . worst case , i may have to pay someone to fix the floor properly when we get done .
Old 05-03-2013 | 11:13 AM
  #65
When you are done you wil fully understand the cost involved.
Unlimited jd is offline
Old 05-03-2013 | 01:04 PM
  #66
c_deezy's Avatar
Slice it out and replace it, since it sounds like you don't have an access panel to get to the whole tank. It's only fiberglass and is easy to fix.
BUT take the time to mask off EVERYTHING first! That dust gets everywhere. Seal off the cabin and mask off everything in the engine room. It's tedious and sucks but is a lot easier than having to try to shop-vac everything after the fact.
If you don't have a dust collector use a shop vac with a drywall dust filter bag (the yellow ones) and have the nozzle in the cutting stream of your grinder/cutting wheel, whatever. The more dust you collect at the source is the less that is getting on your boat, on your body, in your shop, etc.
c_deezy is offline
Old 05-03-2013 | 10:29 PM
  #67
Have Pat give you the stringer location and cut the floor on center of stringers. If you miss add supports where needed. Its only fiberglass. You will have it done before you know it. Nothing wrong with not glassing it over and leave it as access. SUPPORT it properly.
michigan troll is offline
Old 05-04-2013 | 08:35 AM
  #68
camptappakeg69's Avatar
Wow these past 2 post seem like great advice, good luck and hope it is a fast repair...post some pics!
camptappakeg69 is offline
Old 05-04-2013 | 12:00 PM
  #69
One more hour of work and im headed home to start the tear down with him! Im ready! Something different to work on other than a car!
[QUOTEHave Pat give you the stringer location and cut the floor on center of stringers. If you miss add supports where needed. Its only fiberglass. You will have it done before you know it. Nothing wrong with not glassing it over and leave it as access. SUPPORT it properly. ][/QUOTE]
I was thinking the same thing....if we cut on the center of the stringers, when we go to put it back in, we can lay the peice right back down and will be supported. Then glass where the cut is. Ill take pics as much as i can. Im sure we will have a few questions along the way.
GMChevytech is offline
Old 05-04-2013 | 12:16 PM
  #70
Does the boat have one tank or two?
LOTOWONTOPGUN is offline
