Bilge pump in the step... >
Old 08-04-2014 | 05:49 PM
  #31
Originally Posted by sommerfliesby
Mine did the SAME DAMN THING! Wow!
Cool, my post helped us both! I think also, the water just gets a bit stale down there and probably makes sense to flush it every now and then.
Glad I now know how it works.
Pwraddr is offline
Old 08-05-2014 | 10:16 PM
  #32
Originally Posted by ICDEDPPL
The condensation from a A/C unit is clean water... different than the lake water the A/C uses to cool down the condenser (probably knew that) Id say there might be something in the step that its mixing with to cause that water to smell. Ive used some fresh smelling apple dishwashing detergent from the dollar store to make my bilge smell pretty , throw a bottle in the shower!
That sounds like a great idea, you'll be pumping out bubbles at the marina all weekend! Kinda like Lawrence Welk (Pat's favorite Saturday evening show)
509 SC is offline
Old 09-08-2017 | 04:26 PM
  #33
Back to this topic. I just hosed out my bathroom/shower and it is backing up with nothing kicking on. I can see the bilge pump under the shower drain. Should it kick on automatically with both the cabin switch on the dash in the ON position and the water pump switch on the breaker panel in the on position?
302Sport is offline
Old 09-08-2017 | 09:12 PM
  #34
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Yes, it should work that way. Sounds like it may have died. In the mean time, you can use a shop vac on the outside of the boat and pull the water out of the thru-hull/hose/pump.
Sydwayz is offline
Old 09-25-2017 | 12:27 PM
  #35
Default Bilge pump in the step
I am not certain that my Bilge pump is working. When I turn the switch to on I dont hear anything also when I turn on the blower the same I dont hear it making any noise. Could it be as simple as a blown fuse for both?
Henrybug is offline
Old 09-25-2017 | 12:58 PM
  #36
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Not going to be same fuse, but yes you could have blown fuses. What boat do you have?
Take a look at your fuse panel under the dash, and see if you have any corrosion inside the fuse block.
Sydwayz is offline
Old 09-25-2017 | 01:04 PM
  #37
Mines working, I didn't have one of the switches in the correct position!!
302Sport is offline
