2nd Maiden Voyage >
2nd Maiden Voyage
2nd Maiden Voyage
Old 11-17-2018 | 01:51 AM
Originally Posted by Rookie
Getting it dialed in. Mismatched 26" Bravo 1's (round tip and sharp tipped) at 5600-5700 RPM, flat water on Lake Michigan. Need to step up to 28's and might have a line on them to try..Remember this is a non-stepped straight bottom with 454's. Yesterday was a good HP day.
Griff, I didn't forget about the gauge swap. Looks like it might be a winter project for us.
I'm actually getting a pair from Sick Stinger. You can still have mine. I have no use for them and they haven't been hooked up since about 1999, so I'm not sure if they work. If you've got some senders for the 60psi ones, that would be great.
Griff is offline
Old 11-18-2018 | 10:13 AM
Rookie's Avatar
Great! I'll head to the shop this week and try to dig up the senders.
​​​​​​​Thanks
Rookie is offline
Old 02-21-2019 | 05:55 AM
Rookie,
Did you ever end up tearing the boat down for paint etc?
I boat from holland as well will have to keep my eyes open
Rossman is offline
Old 02-21-2019 | 09:07 PM
Rookie's Avatar
Originally Posted by Rossman
Rookie,
No, keeping the boat together this winter. Building engines to put back in my Panther and get that ready to sell this spring, also fixing up my cruiser to sell and going to start on a couple of car projects that have been on hold for too many years.
Definitely need to meet up this summer. I'm out every weekend on one of my boats, usually go out of GH,
Rookie is offline
Old 04-10-2019 | 08:38 PM
Rookie's Avatar
Griff, when you get the gauges installed. Let me know how the senders work. I'm going MPFI and will need to get senders for my EFI fuel gauges.
Rookie is offline
Old 04-13-2019 | 12:53 PM
Going to be more difficult than I thought to connect the senders. The schrader valve on the fuel rail is too close to the upper manifold for them to connect directly to the rail. I will have to find some sort of extension/adapter. I tried to test them but probably wasn't getting a good enough ground to get them to work.
Griff is offline
