Engine hatch switch >
Engine hatch switch
Engine hatch switch
Old 07-03-2018 | 03:32 PM
Default Engine hatch switch
Anyone know where I can get one of these switches? It's for the engine hatch, so I guess its considered a momentary switch
toyboat991 is offline
Old 07-04-2018 | 01:58 AM
Rookie's Avatar
It's an on-off-on momentary double pull double throw (dpdt) switch. Carling brand I believe .
Rookie is offline
Old 07-05-2018 | 10:28 AM
When I put new ones in mine, I found them online.
Instead of having that huge light when theyre on, my new ones have a small red LED so youre not getting blinded while driving at night.
But you and Rookie are correct on what it is.
Just search momentary rocker switch, and make sure its weatherproof.
TooLateVTEC is offline
Old 07-05-2018 | 11:49 AM
ActiveThunder's Avatar
https://www.onlinecomponents.com/car...tml?p=17002589
ActiveThunder is offline
Old 07-06-2018 | 03:12 PM
I have a used one I pulled out of mine when I replaced all the switches. Looks a little dirty.
mbccenter is offline
Old 07-06-2018 | 05:53 PM
Default Dash switch
Momentary , no light right? If so , how much you want for it?
Old 07-23-2018 | 04:58 PM
Gordo's Avatar
Charter Member #94
It sounds like you just got lucky. I had a heck of a time finding that exact switch because Carling changed styles. I had to buy 6 at one time, which worked out because the switch seems to be the weak link.
Abby-someone
Gordo is offline
Old 08-06-2018 | 07:04 PM
Rookie's Avatar
Still available? Mine is on the fritz again. I'm going to hook up a dual relay or a winch motor relay so I can get some speed out of the hatch motor and save the switch...
Rookie is offline
Old 08-20-2018 | 08:06 PM
Rookie's Avatar
Just an FYI, takes the amps off of the switch and hatch goes up twice as fast.
https://www.ebay.com/itm/12-VOLT-WIN....c100005.m1851
Rookie is offline
