Extreme Measures... Make Over Edition >
Old 05-30-2021 | 10:30 PM
  #101
Rookie's Avatar
Got a lot accomplished today. Got the engines set in. Had to spend quite a bit of time aligning the the gimbal bearing into the coupler. The outer stringers were replace so no holes were drilled. Had to get everything aligned, bolts tightened and C-clamped the mounts to the new stringers. then drilled out the holes.
Now need to plumb the new fuel system, wire the whole EFI system in and freshen up drives.
Rookie is offline
Old 07-21-2021 | 07:48 PM
  #102
bencini231's Avatar
Looking very good now. Any updates on more progress?
bencini231 is offline
Old 07-22-2021 | 05:17 PM
  #103
boatfreak's Avatar
This thing is looking awesome and has been a great thread. I'm really looking forward to seeing it completed and in the water.
boatfreak is offline
Old 07-22-2021 | 08:46 PM
  #104
Rookie's Avatar
Slow progress. Realizing that my engines were originally out of my Panther I needed to build new engine wire harnesses, order all new Gaffrig senders, run/build all new oil lines and fuel system. wired analog/digital systems. (EFI) also new gimbal bearings. The rigging is so time consuming now that everything has to be wired nice and neat with proper planning. I bought so many -AN brackets, couplers, zip ties, hose/wire holder thingy mounts... I'm also moving batteries to level out the boat. It lists terribly to the starboard side. I plan to work on it all day tomorrow and maybe Saturday. Should be able to hopefully fire them next week.
During this time Valako (JimV) and I also moved out of our shop.
I have more pics of progress I'll add.
Rookie is offline
Old 09-15-2021 | 09:02 PM
  #105
Rookie's Avatar
Not much to update. Majority of August was mid 90°s and inside my pole barn was 100°+ after work. I did get my above list 90% complete.
Then I said f#ck it and broke out the Panther and have been boating the last 3 weeks!. lol
Rookie is offline
Old 12-07-2021 | 07:51 PM
  #106
bencini231's Avatar
It's been awhile so any updates on the progress lately?
Old 12-07-2021 | 08:14 PM
  #107
That definitely looks like a lot of work...nice one!!
Gboat is offline
Old 12-19-2021 | 09:47 AM
  #108
Rookie's Avatar
I have the boat all wired up, EFI installed, relays, fuses, fuel. Need to put on headers, throttle linkage, rebuilding Bravos, install interior and I should be done. Also have other projects going on. Not too far away from completing.
Rookie is offline
Old 12-19-2021 | 03:51 PM
  #109
Rookie's Avatar
These just arrived today for my other project.
Rookie is offline
Old 04-10-2022 | 01:50 PM
  #110
bencini231's Avatar
Ok, you are well over due for a update on this project....
