Counter tops
Old 02-23-2022 | 12:08 PM
bencini231's Avatar
I used debond when removing my transom assemblies that were covered in 5200 when they were installed new. Debond broke the 5200 down to where it was pliable as a rubber band, which made it super easy to work with. All you need in a small crack to get to where the adhesive is and spray it down. https://www.westmarine.com/buy/marin...aner--12222295
bencini231 is offline
Old 02-23-2022 | 12:42 PM
They have 1/4" solid surface [corian] You could put that or carbon fiber over the top and edge or trim the edge with vinyl like the newer ones. I dont know how they did the 2004.
harsin is offline
Old 02-23-2022 | 07:00 PM
Thanks guys all good ideas. I think I will look into having it covered over with another thin solid surface material first to see if it can be done to look right. Tearing it out sounds doable but messy. I'll post some before and after pics.
DaveK26 is offline
Old 02-24-2022 | 09:03 AM
bencini231's Avatar
Here's the cuddy being built for my 33 AT Remedy. This should give you a idea of how the corian was installed over the wood.
