Opinion On 25 Tantrum >
Old 06-17-2005 | 07:57 PM
  #31
R Addiction's Avatar
AT Cult Member #3
Default Re: Opinion On 25 Tantrum
This is her in all her glory!!!
R Addiction is offline
Old 06-23-2005 | 11:25 PM
  #32
dencam7's Avatar
Originally Posted by Ike
Den, This is R'Addiction (using my brothers screen name). Boat has 502 Mag Bravo 1 W/bravo one 4 blade prop 26p. Tweaked by murphys for more rpm. Had a stock 24p and it went right to the rev limiter. Lost cruise speed though. 502 has Gil exhaust and a K&N filter ....thats it!!
Thanks for the info R'Addicted !!Would have replyed earlier but the site was down. Do you do any boating in the Pittsburg area? We do some boating around Oakmount . Maybe we will run into you .Like to see your boat!
dencam7 is offline
Old 06-24-2005 | 10:04 AM
  #33
AT Cult Member #3
dencam, I boat in the Chesapeake Bay.....We may be going to SML on Labor Day......
Old 06-24-2005 | 03:30 PM
  #34
AKA NoMoBoatin
John you and Leslie better show up that weekend.Its a great time.
docmanrich37 is offline
Old 06-24-2005 | 04:16 PM
  #35
AT Cult Member #3
Do I get to drive the big boat??? Huh...Huh....Do I...Do I?
Old 06-26-2005 | 02:27 AM
  #36
Originally Posted by surfacetension
I just found a 25 tantrum, Other than the 8.0 beam I like the look, does this have that sunken center section on the deck? and it has a 454/385 is this a little underpowered??? they are asking Around 41K with a trailer any thoughts??
What year is the boat? I have a 1994 Cannon 25' . I had a 454 Mag 365 HP. this boat scoots. I went to poker runs and people did not believe I only had a 365 Mag. They probably did not realize I ran this boat WOT. the entire time. I have since upgraded power. I now have a 500 hp performance series merc. the motor is fresh and it rocks! but I would say it is still under powered. I have 100% faith in this boat and motor. My personal feeling, if I'm not scared to drive it, it is not fast enough and therefore underpowered. My boat is mint and I am thinking of selling (37kish). if you are interested call 847 816 8468. The only reason for selling is a friend and I are thinking of building a race boat. I'm looking for a thunder hull in any condition to race P5.
Cannon8468 is offline
Old 06-26-2005 | 05:59 AM
  #37
AT Cult Member #3
A Thunder in P5....Sweet!! Hopefully see you in Key West!!!
Old 10-06-2005 | 09:45 PM
  #38
Full Force's Avatar
surfacetension,did you used to have a chris craft 245 limited?
Full Force is offline
Old 10-11-2005 | 03:52 PM
  #39
The 25' Tantrum is without a doubt one of the best riding rough water boat built. Solid as a rock, feels much bigger than it is, will easily handle open ocean, deep cockpit...the gunnels come up to your arm pits, nice size cabin with good headroom. The 454/bravo is an ok package for the boat...an HP 500 makes the boat come alive. I should know, driven plenty of them, used to work for Pat at the factory. Steve E.
JUPITER PULSARE is offline
Old 10-11-2005 | 08:43 PM
  #40
Jupiter Palsare,
I have a 1998 Tantrum with a 500 HP in it. My boat was originally built for the Smith Brothers Racing.
Seeing that you have run a lot of Tantrums what was a good speed for a 25" tantrum with a 500 HP in it for you?
I run my boat in mostly Pennsylvania and at WOT 1/2 tank of fuel, two people my best was 75.5 on GPS.
I have a Bravo 1 28 pitch prop that Mercury racing has done some work on it.
Your thoughts?
Thanks in advance
Active Mike
Active Mike is offline
