Opinion On 25 Tantrum
#61
Sorry gang, trying to keep up, and not doing it very well lately.
Anyway, Call John Janaky
DAH Pro-pellers
34111 Washington Ave.
Burlington, WI. 53015
Measure the X by measuring from the pivot point on the transom assembly down to the lowest point of the keel in the center of the transom.
For approx. numbers, 14" to 15" is pretty standard for recreational boats, with most race boats and high end performance stuff up around 19 or so.
(APBA Factory 1 rules had a limit of 19" for step bottom boats and 19.5" for straight bottoms like the 25 Thunder).
I'll measure mine as soon as I get a chance.
DAH Pro-pellers
Abby-someone
Abby-someone
#63
DAH Pro-pellers
DAH Pro-pellers
Was wondering if you had a chance to make it to your boat to get the X dimension measurement ?
Also wanted to clarify something with you. When measuring the X-dimension it is taking from the pivot point of the lower unit. which pivot point the up and down or the left to right?
I couldn't seem to get a number in the range that you gave me so I want to confirm.
Thanks,
Mike
#64
Originally Posted by Active Mike
Jupiter Palsare,
I have a 1998 Tantrum with a 500 HP in it. My boat was originally built for the Smith Brothers Racing.
Seeing that you have run a lot of Tantrums what was a good speed for a 25" tantrum with a 500 HP in it for you?
I run my boat in mostly Pennsylvania and at WOT 1/2 tank of fuel, two people my best was 75.5 on GPS.
I have a Bravo 1 28 pitch prop that Mercury racing has done some work on it.
Your thoughts?
Thanks in advance
Active Mike
Your thoughts?
Thanks in advance
Active Mike
#65
Originally Posted by JUPITER PULSARE
Sorry for responding late Mike, been busy preparing for and recovering from Hurricane Wilma...Seems like Gordo has jumped in and answered many questions. A bone stock 25 with an Hp 500/bravo will run upper 70's all day long. Tweaked with the right X-dimension and prop you may get over 80 mph which is great for a 24 degree hull that measures 24'6" down the center line!! The greatest thing is the mid range accelleration in that boat when powered by the Hp 500 carb or efi. The boat is very throttle responsive and a joy to drive.
I wish you luck with your rebuilding from Hurricane Wilma.
What kind of props do you think worked best on the tantrum with the 500HP?
Thanks in advance,
Mike
#66
Jupiter Pulsare,
Thanks in advance,
Mike
Thanks in advance,
Mike
HEY MIKE WHATS NEW, DONT FORGET THAT HERE IN PA WE ARE 3/4 MPH SLOWER THAN RUNNING AT SEA LEVEL IN THE SALT. I THINK AT 74 /75 YOUR ABOUT AT THE MAX W/ YOUR SET UP. WHEN I BOUGHT THAT BOAT FROM THUNDERDAN HE TOLD ME #S I NEVER SEEN UP HERE IN PA AND HE RAN IN THE SALT AT SEA LEVEL. ALSO MY 32 AUDACITY WENT 91 IN THE SALT AND BEST I EVER SEEN AROUND HERE IS 87.
32 THUNDER RICK
#67
Hey Mike, if I remember correctly (??), we were swinging a Bravo one 26, Lab finishing will give you an extra 2 mph at wot. By the way, Thunder Rick is correct. The boat will run faster in the salt water (more bouyancy) and at sea level (more oxygen to feed those hungry cylinders). Pat could give you better feedback on prop choice....he's got more seat time in that boat than anyone. The reality of a 25' Tantrum is that when the water gets snotty, that boat will crush it's way through and leave other similar sized boats in it's wake!!
#68
How are ya by the way?
#69
You are sooo right Steve!!! I've lost more pairs of sunglasses turning my head to see how far back everybody is!!!
#70
32 THUNDER RICK
32 THUNDER RICK
All is good here. I'm just trying to dot my I's and cross my t's with the boat. I still want to try to dial the porpoising out if I can.
I'll have to keep digging on the prop issue.
Be good.
